I am listening to something new here today.
0 Members and 1 Guest are viewing this topic. Read 9219 times.
avahifi
    • http://www.avahifi.com
« on: 25 Feb 2015, 04:39 pm »
Getting tired of having only one good FM station here, KSJN PBC classical, I was happy when Mithat Konar, a friend and consulting EE, suggested a Bluetooth Music Receiver.
So I invested $30 for a Satechi wireless bluetooth receiver and connected its optical digital output to my Fet Valve DAC and after exploring available internet audio channels for a bit, discovered a series of Audiophile music programs originating in Greece, of all places.  Its found on Radio.net.
They have five channels ranging from Classical, Baroque, and Jazz, to soft Jazz - Pop and more.
The good thing is that they stream at 320 kpbs eliminating the rough edge on string sounds heard at lower streaming rates.  I am going to call the sonic performance equal to my own broadcast FM tuner and commercials and lots of talk between music is completely eliminated.
Pretty good deal for 30 bucks.
Frank Van Alstine
dB Cooper
Re: I am listening to something new here today.
« Reply #2 on: 26 Feb 2015, 04:13 am »
Another great classical source is KWAX-FM, a terrific classical station based in Oregon. Here is the URL for their 320K AAC stream:
http://184.171.104.41:8000/listen.m3u?sid=1%22
Another contender used to be BBC Radio3, but they recently discontinued their excellent 320K AAC stream and now top out at a mediocre 128K mp3. Too bad, as they used to have some of the best programming. Bye bye Beeb....
charmerci
« Reply #3 on: 26 Feb 2015, 06:35 am »
www.tidalhifi.com
20 bucks/month for CD quality.
adydula
« Reply #4 on: 1 Mar 2015, 03:45 pm »
I have an Onkyo 2 ch  network receiver I got from accessories4less website a few years back....so I could listen to Pandora and other net stuff. I found it had this "vTuner Internet Radio" installed in the firmware selections and its pretty good.
The little 2 ch onkyo is a neat little marvel that has not only the v Tuner, but Pandora, Rhapsody, Sirius XM, Last.fm International, Slacker, Mediafly, Spotify, AUPEO! PERSONAL RADIO,  quite a selction. Ethernet cable attached and works well.
I have those little modified Pioneer Speakers Frank talked about several months ago attached to it for music and pc stuff.
Aint technology wonderful!!
and Frank the UltraValve is still running great here!!
Alex
Brett Buck
« Reply #5 on: 4 Mar 2015, 04:16 pm »
   I would also suggest poking around for NRK, which appears to be Norway public radio. They have a bunch of channels (I prefer NRK Jazz - which sounds like "an-r-koo yass" when they pronounce it) and there should be a 320 kbps stream for each. You *do* get the news on the hour, but the sound quality is excellent. It used to be listed on iTunes radio, too, and I was streaming it over AirPlay to my Omega DAC with excellent results.
     Brett
dB Cooper
« Reply #6 on: 4 Mar 2015, 10:57 pm »
Found a 192K stream but my Norwegian is a little weak. Any chance you have a url?
srb
« Reply #7 on: 5 Mar 2015, 01:11 am »
So far I haven't yet found any NRK streams that are higher than 192kbps mp3.
NRK Jazz - 192kbps mp3
http://lyd.nrk.no/nrk_radio_jazz_mp3_h.m3u
NRK Jazz - 96kbps aac
http://lyd.nrk.no/nrk_radio_jazz_aac_h
Although the aac+ compression algorithm is superior to aac, and aac superior to mp3 (given the same bitrate), in this case the mp3 stream being twice the bitrate of the aac stream is better sounding to my ears (but closer than one might think).
strat95
« Reply #8 on: 5 Mar 2015, 04:24 am »
I believe Linn Records has a few internet streams at 320kbps.
dB Cooper
« Reply #9 on: 5 Mar 2015, 04:42 am »
Linn has a record label and apparently they play only the artists that are on it. Some are good but the playlist is kind of monotonous as a result. I remember every time I logged in, this same jazz female vocalist album seemed to be on.
srb
« Reply #10 on: 5 Mar 2015, 05:10 am »
Claire Martin!
maty
Internet Radio xml file. MusicBee.
« Reply #11 on: 5 Mar 2015, 08:48 am »
You can copy at simple text editor this code and save with xml extension.  *******.xml
After you must import to the audio player. In Windows I prefer now MusicBee 2.5 beta because it uses BASS audio library. It can use Wasapi and ASIO but my DAC (ODAC USB) sounds better with BASS.
-> http://getmusicbee.com/forum/index.php?topic=13648.0
-> http://www.un4seen.com/
Code: [Select]
<?xml version="1.0" encoding="UTF-8"?>
<opml version="2.0">
  <head>
    <title>MusicBee Radio Station List</title>
    <dateCreated>Thu, 26 Feb 2015 20:53:56 GMT</dateCreated>
  </head>
  <body>
    <outline text="Audiophile Baroque" description="" category="Baroque Classical/MP3/320k/" type="link" url="http://50.7.173.162:8010/" />
    <outline text="Audiophile Classical" description="" category="Classical/MP3/320k/" type="link" url="http://50.7.173.162:8012/" />
    <outline text="Linn Classical" description="" category="Classical/MP3/320k/" type="link" url="http://89.16.185.174:8004/stream" />
    <outline text="Audiophile Jazz" description="" category="Jazz/MP3/320k/" type="link" url="http://50.7.173.162:8014/" />
    <outline text="Canal Jazz" description="" category="Jazz/MP3/320k/" type="link" url="http://radiart.eu:10024/stream" />
    <outline text="Linn Jazz" description="" category="Jazz/MP3/320k/" type="link" url="http://89.16.185.174:8000/stream" />
    <outline text="KWAX-FM" description="" category="Classical/MP3/320k/" type="link" url="http://184.171.104.41:8000/listen.m3u?sid=1%22" />
    <outline text="SRO Rádio Klasika" description="" category="Classical/MP3/Bitrate desconocido/" type="link" url="http://live.slovakradio.sk:8000/Klasika_256.mp3" />
    <outline text="SRR Radio România Muzical" description="" category="Classical/MP3/Bitrate desconocido/" type="link" url="http://live.slovakradio.sk:8000/Devin_256.mp3.m3u" />
    <outline text="AVROTROS - Klassieken" description="" category="classical/MP3/192k/" type="link" url="http://icecast.omroep.nl/radio4-klassieken-bb-mp3.m3u" />
    <outline text="SWR2" description="" category="Classical/MP3/256k/" type="link" url="http://mp3-live.swr.de/swr2_m.m3u" />
    <outline text="WDR 3, © Westdeutscher Rundfunk Köln." description="" category="Classical/MP3/256k/" type="link" url="http://www.wdr.de/wdrlive/media/mp3/wdr3_hq.m3u" />
    <outline text="Klasu Pro High" description="" category="Classical/MP3/320k/" type="link" url="http://stream.iradio.fi:8000/klasupro-hi.mp3.m3u" />
    <outline text="Danmarks Radio P2" description="" category="Classical/MP3/256k/" type="link" url="http://live-icy.gss.dr.dk:8000/A/A04H.mp3.m3u" />
    <outline text="Radio Klassisk" description="" category="Classical/MP3/Bitrate desconocido/" type="link" url="http://onair.100fmlive.dk/klassisk_live.mp3.m3u" />
    <outline text="Classical 102" description="" category="Classical/MP3/192k/" type="link" url="http://tuner.classical102.com/listen.pls" />
    <outline text="Radio 4" description="" category="Classical/MP3/192k/" type="link" url="http://icecast.omroep.nl/radio4-bb-mp3.m3u" />
    <outline text="NRK Klassisk" description="" category="Classical/MP3/Bitrate desconocido/" type="link" url="http://lyd.nrk.no/nrk_radio_klassisk_mp3_h.m3u" />
    <outline text="SR Klassiskt" description="" category="Classical/MP3/Bitrate desconocido/" type="link" url="http://sverigesradio.se/topsy/direkt/1603-hi-mp3.pls" />
    <outline text="RNE Radio Clásica" description="" category="Classical/MP3/Bitrate desconocido/" type="link" url="http://radiolive.rtve.es/radioclasica.m3u" />
  </body>
</opml>
« Last Edit: 5 Mar 2015, 10:31 am by maty »
Guy 13
« Reply #12 on: 5 Mar 2015, 12:34 pm »
www.tidalhifi.com
Hi charmerci,
I went on the tidal site and as usual,
it's not available for planet Vietnam.
Si, I will wait until I get back to Canada.
Thanks for the link.
Guy 13 on planet Vietnam.
dB Cooper
« Reply #13 on: 5 Mar 2015, 08:12 pm »
maty
1000 Kbps Lossless Uncompressed FLAC
« Reply #14 on: 6 Mar 2015, 10:29 am »
EuroparadioJazz
-> http://www.europaradiojazz.org
-> -> http://www.europaradiojazz.org/page3/page15/index.html
at the end:
- 1000 Kbps Lossless Uncompressed FLAC
http://www.europaradiojazz.org/stream.flac.m3u
It sounds better with foobar2000  :scratch:
maty
« Reply #15 on: 18 Mar 2015, 03:29 pm »
foobar2000 recognizes fewer stations (does not recognize the finished in pls, among others). You can import them, prior saved in file with extension *.m3u
Code: [Select]
http://sr7.inmystream.info:9100/stream.flac
