0 Members and 1 Guest are viewing this topic. Read 2306 times.
I wired a lot of our network after fighting wireless for a while. I have an light duty angle drill I likehttp://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=PS11-2Abut in the case of drilling near rim joist, I think this is way easierhttp://www.lashen.com/vendors/greenlee/hole_making.aspCut hole for your low voltage frame and drill down through plate an subfloor. Unchuck bit and leave in hole. Into crawl space, find bit, attach CAT6 and pull back up into room.
Did you consider using powerline networking adapters instead of hard wiring directly from the router to the computers?
