SOLD: SOtM sDP-1000
0 Members and 1 Guest are viewing this topic. Read 2896 times.
wellpleased
SOLD: SOtM sDP-1000
« on: 18 Feb 2015, 03:25 am »
Demo unit in like new condition. Asking $2100. Not only does this DAC hang with the likes of the Vega, AQUA La Voce s2, Metrum Hex and any other top flight DAC under $3500, it virtually surpasses them all because of it's fully featured/functional analogue pre-amp section which is really exceptionally good (see the 6 moons review). Please contact me directly if interested.
Specification
USB input
USB specification 2.0 or higher
USB audio class 2.0
32bit/192KHz PCM & DSD playback
Native ASIO support
Optical, Coaxial, AES/EBU input
Max bit-depth : 24bit
Sampling rate : 32KHz, 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz
Impedance
Coaxial, BNC : 75Ω
AES/EBU : 110Ω
Balanced input
Max input voltage : 4 Vrms
Input impedance : > 10kΩ
Frequency range : 20~20KHz @ ±0.1dB
Unbalanced input
Balanced output
Output voltage at 0dB : 3.8 Vrms ±5%
Output impedance : 47Ω ±5%
THD : < 0.003% @ 1KHz, 0dB
Unbalanced output
Volume control
Setting range : -75 ~ +10dB, 0.5dB step
Charging power input
Input voltage : 9Vdc ±1%
Max input current : 3A
Operating environment
Operating temperature : 10°C ~ 35°C
Storage temperature : -10°C ~ 50°C
Operating & storage humidity : 10% ~ 90%
Dimensions
Width : 360 mm
Height : 68 mm
Depth : 245 mm
Weight
4 Kg >
« Last Edit: 15 May 2015, 12:37 pm by wellpleased »
