Is this worth anything?
0 Members and 1 Guest are viewing this topic. Read 1424 times.
Gzerro
« on: 17 Feb 2015, 04:35 pm »
A friend purchased a house and this was left behind. It is going to the dump if I don't take it, as they don't know anyone else still crazy enough to bother with old records.
Seems a shame to toss, but I really have no space/use for it. Any demand for these things? If so I would probably donate to a thrift store and hope someone gets some use out of it.
rollo
  • Rollo Audio Consulting -
Re: Is this worth anything?
« Reply #1 on: 17 Feb 2015, 07:43 pm »
   If it is a Garrad TT yes. Any tubes in there ? Where ya located ?
charles
Mike Nomad
« Reply #2 on: 17 Feb 2015, 07:46 pm »
Is it functioning? If the amp is a tube rig, I would pull it out. Can't see the titles, but, there are a number of 10" in the stack. There might be some valuable pieces.
Gzerro
« Reply #3 on: 17 Feb 2015, 08:04 pm »
I don't have the table yet. Located in Sacramento.
It says "Voice of Music" on the table, a bit hard to read from the photo. A quick google shows there are some collectors, or at least used to be.
neobop
  • BIRD LIVES
« Reply #4 on: 18 Feb 2015, 02:59 pm »
Voice Of Music were idlers.  The changer looks like a Garrard, but I really have no idea.  If you have the model number maybe you can find it here:
http://www.thevoiceofmusic.com/modfind_consoles.html
neo
