BDP Digital Player and WoL
0 Members and 1 Guest are viewing this topic. Read 1638 times.
RonCH
« on: 16 Feb 2015, 09:00 pm »
Hi Chris,
Would it be possible to include Wake-on-LAN (WoL) in the BDP?  It would be a really nice feature to have.  Maybe on startup of the BDP could send a magic packet to wake up my NAS.
thanks
Ron
unincognito
    • bryston.com
Re: BDP Digital Player and WoL
« Reply #1 on: 16 Feb 2015, 11:59 pm »
you could likely add this feature using the startup script
Code: [Select]
#!/bin/bash
apt-get install etherwake
etherwake <mac address of the device you want to wake up>
RonCH
« Reply #2 on: 18 Feb 2015, 09:41 pm »
Code: [Select]
#!/bin/bash
Thanks Chris,
It works!
Although you need a -y option on the apt-get.  So the command looks like this:
apt-get -y install etherwake
etherwake  00:11:32:1A:XX:XX
The fly in the ointment is that it takes 55 seconds to install etherwake.  That's too long for me.
I know you effectively get this question a lot, but I'll ask it anyway.  Is there a way to have it so that I don't have to install etherwake with every boot up?
regards
Ron
unincognito
    • bryston.com
« Reply #3 on: 19 Feb 2015, 01:45 am »
Thanks Chris,
It works!
regards
Ron
Your right, my bad.  The filesystem runs in a live environment like a Ubuntu live cd.  If you wanted to get creative you could download the individual dpkg files that make up etherwake to the user space (/mnt/img/) and install them from there, rather then download the package each time.
Cheers
RonCH
« Reply #4 on: 7 Mar 2015, 08:28 am »
Cheers
Hi Chris,
Thinking about it we could just do unpack etherwake and WoL if the NAS is asleep.  So that means we have something like this in the startup:
#!/bin/bash
if ! (ping -c1 10.0.1.201)
then
  etherwake   00:11:32:1A:53:D9
fi
I would have liked to have ( with the output redirected to the null device):
#!/bin/bash
if ! (ping -c1 10.0.1.201 &> /dev/null )
then
fi
but there's a bug in the save for your Startup-Script window and it doesn't save.
As always thanks for all your help.
Ron
