Possible problem w/ Ortofon Quintet--successful repair!
0 Members and 1 Guest are viewing this topic. Read 3483 times.
S Clark
I just mounted an Ortofon Quintet red, and after a couple of hours of listening, I'm liking what I hear...
but here's the problem.  When mounted and set at 2.2 g, just under the recommended 2.3, the body barely clears the vinyl.  It looks like the gap is the thickness of maybe 2 sheets of paper.  Lacking enough experience, I need to ask if this is typical, or is the suspension of the cartridge weak?
« Last Edit: 18 Feb 2015, 01:19 am by S Clark »
Wayner
Re: Possible problem w/ Ortofon Quintet
« Reply #1 on: 16 Feb 2015, 09:02 pm »
What did you use to measure the weight?
Wayner
S Clark
« Reply #2 on: 16 Feb 2015, 09:10 pm »
Wayner
a set of digital scales checked and calibrated, don't think the problem is there.  Any other ideas?  By the way, thanks for any and all suggestions.
Wayner
« Reply #3 on: 16 Feb 2015, 09:13 pm »
Had to ask. Some just rely on their counterweight dial.
Wayner
S Clark
« Reply #4 on: 16 Feb 2015, 09:14 pm »
No, you're right to cross off the most obvious source of error.
neobop
  • BIRD LIVES
« Reply #5 on: 17 Feb 2015, 12:14 am »
2 pieces of paper?
It's defective.  Suggest you return it ASAP.  It happens.
neo
S Clark
« Reply #6 on: 17 Feb 2015, 02:07 am »
2 pieces of paper?
neo
Thanks, Neo.  That's what I suspected.
S Clark
« Reply #7 on: 18 Feb 2015, 01:18 am »
It turns out that I was able find the problem and fix it.  The cartridge body/shell? and been misaligned with the actual guts of the cartridge, so that a gap of about 1/16" opened at the top, moving the body down further and putting the guts further up into the shell. Some kind of a foam collar around the barrel that holds the stylus had slipped and interfered with the fit.  Less stylus was sticking out.  I managed to pop the shell off the guts, scrap out the old glue, realign it, and superglue it back together.  Playing fine now with adequate space between cartridge and lp.
Thought I'd post the outcome in case anyone else runs across this.
Scott
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #8 on: 18 Feb 2015, 01:51 am »
Scott
 :o
That's unfortunate. I would inform Ortofon of this, as they are known for strict quality control. My Cadenza Bronze is very well made and the azimuth is nearly spot on.
Best,
Anand.
neobop
  • BIRD LIVES
Re: Possible problem w/ Ortofon Quintet--successful repair!
« Reply #9 on: 18 Feb 2015, 01:53 pm »
Scott,
Good thing you were successful, congratulations.  By opening the body I'm sure you voided the warranty.  Had you not been successful it might have been a problem.
neo
S Clark
« Reply #10 on: 18 Feb 2015, 02:11 pm »
Well, it probably wasn't smart.  But when I saw what was wrong, I have a dissecting scope and lots of experience with gluing tiny bits of fossils, so I figured I'd give it a try.  Some of the glue did run, so I should have used a more viscous variety of superglue.  Fortunately, it never ran into a critical area.
