Lowering ringing in Capacitors
0 Members and 1 Guest are viewing this topic. Read 2856 times.
Lizard_King
  • Tubes Rule!
« on: 10 Feb 2015, 09:28 pm »
Does anyone her use Herbie's Halo products to treat noise in capacitors?  If yes, can you please share your experiences?  Thanks in advance.
Liz
hifiman5
Re: Lowering ringing in Capacitors
« Reply #1 on: 6 Oct 2015, 11:02 pm »
I bought a grungebuster sheet and cut it into tiny pieces based on the capacitor's size and stuck it onto the top of smaller caps and even onto the sides of very large capacitors.  Very inexpensive but effective way to eliminate capacitor ringing and grunge!
Folsom
« Reply #2 on: 7 Oct 2015, 12:37 am »
Yes and no... it can help with mechanical ringing but it's not going to stop electrical ones that say occur between parallel large and small caps.
