Price Drop: DALAUDIO Studio LM3875 Monoblock Amps - $300
0 Members and 1 Guest are viewing this topic. Read 1981 times.
tlarwa
I bought these a few weeks ago, but decided to go back to tubes with my Forte II's. No issues with them at all, and they sound great. Very powerful, and extremely detailed. If your source is bad, you'll know it! Small footprint, and they stack, so they don't require much room on your equipment stand.
•Chip Amp type: One (1) per each Mono Block of National Semiconductor LM series National Semiconductor - LM3875 - High-Performance 56W Audio Power Amplifier with a total power output in excess of 100 watts (50 watts per channel)
•Main Board: Chipamp Brian Bell’s - Please see website that sells the PCB’s and LM Series amplifier kits. All are high quality printed circuit boards.
•Power Supply: Dual PSU is constructed with Brian Bell PCB that utilizes dual pairs of four MUR860 diodes. Filtering is accomplished through 4.7 UF 100V capacitors on PSU board.
•Transformer (Mains): (Toroidal) 160VA 22v/22v, made by Avel Lindburgh Inc. (Y236503)
•Speaker OutPut Terminal Type: Standard Color Coded Black and Red - For direct wire compression or banana plug
•Audio Input Jacks: Standard Gold plated (color coded insert) RCA jacks
•Chassis Type: Studio - small form factor extruded aluminum anodized black with DALAUDIO faceplate •Approximate Dimensions: Depth 10.25”, Height 3.75”, Width 6.75” (each)
•Power Input: Removable IEC 3 prong power cord
•Power Switch: Front panel power switch with indicator lamp.
 •Fuse: Internal non servicable bus type fuse.
•LM3875 Output and Operating Characteristics per National Semiconductor Datasheet: The LM3875 is a high-performance audio power amplifier capable of delivering 56W of continuous average power to an 8 Ohm load with 0.1% THD+N from 20Hz to 20kHz. See our Gainclone FAQ for extended specs for the LM3875.
I'll split shipping costs. Contact me with your location and I'll calculate the shippnig cost. Pic is a stock image, but I can get you actual pictures.
Check them out here: http://www.dalaudio.com/Studio-3875-Mono-Block-Chip-Amps-p/dals3875mob-r2.htm
« Last Edit: 12 Feb 2015, 08:14 pm by tlarwa »
tlarwa
Re: Price Drop: DALAUDIO Studio LM3875 Monoblock Amps - $300
« Reply #1 on: 12 Feb 2015, 08:15 pm »
Bump for price drop and I added actual photos of the amps.
tlarwa
« Reply #2 on: 22 Feb 2015, 11:56 pm »
Sold
