0 Members and 1 Guest are viewing this topic. Read 2170 times.
Just finished a build. 2 X NC400 and 1 X SMPS1200A400. One of the channel is not producing any music. I have swapped XLR cables and speaker cables. Seems to be an amp issue? All the LEDs light up. Both amps light up the same. Not sure what tells me.
Thank you for the suggestion. Swapped. Same outcome. I have contacted Hypex. Waiting to hear what they say.
Yes. The good NC400 still works. And the "bad" NC400 still doesn't.
Just to clarify. I'm using a single SMPS1200A400. So I can only swap the power input into the NC400. So after swapping, it is still only the good amp that is working.
