my modwright transporter would not power up?
0 Members and 1 Guest are viewing this topic. Read 1355 times.
orientalexpress
« on: 4 Feb 2015, 04:39 pm »
can anybody fix this?Thanks
lapsan
srb
Re: my modwright transporter would not power up?
« Reply #1 on: 4 Feb 2015, 05:17 pm »
No, it would likely take a qualified repair technician to fix it.   ;)
There is an internal fuse.  Occasionally a fuse in a component might blow and when replaced the unit is fine.  But if there is a blown fuse and you replace it and it blows again you will obviously need to get it serviced.  I suspect you are outside the U.S. (China?), and shipping might be prohibitive, but I would email ModWright and see if they can help or point you in a direction.
orientalexpress
« Reply #2 on: 4 Feb 2015, 06:06 pm »
the internal fuse is fine,but there no power to the front display.Thanks
lapsan
Hear Clifford Brown
« Reply #3 on: 4 Feb 2015, 07:40 pm »
A few years ago Dan Wright told me the display can fail on the Transporter, and if that happens you are out of luck since replacements are not available from Logitech.
