0 Members and 1 Guest are viewing this topic. Read 4956 times.
I have seen a problem with almost all plate amplifiers in that their "automatic" circuit "on" sensing circuit goes to hell, then the plate amp will simply not come on. Sometimes, the fix is to unplug it for awhile (like a day) and plugging it in again may restore the sensing circuit. I've had this happen a couple of times with various subs and when I get the circuit to work again, I manually use the on/off switch, switching the amp on when I need it and off when I don't. This seems to keep the sensing circuit at bay, at least for awhile.
Do all plate amps make with same size and dimension ?just curious
(or passive towers with just built-in subs, like Def Tech or Golden Ear)
Or maybe some beautiful SALK Exotica 3's in Mexican Ziricote.
