Stacking BP26 & MPS-2
0 Members and 1 Guest are viewing this topic. Read 2496 times.
electricbear
« on: 3 Feb 2015, 06:28 pm »
Is there any reason that I should not stack a BP26 and a MPS-2 together ?
srb
electricbear
Re: Stacking BP26 & MPS-2
« Reply #2 on: 3 Feb 2015, 07:02 pm »
Thanks for finding that in the archives. Told me exactly what I needed.
AJAudio
  • The sweet sound of music...
« Reply #3 on: 6 Feb 2015, 02:59 am »
Hi,
The answer can also be found in the BP-26 manual located here;
http://www.bryston.com/PDF/Manuals/300018[BP26].pdf
Page 4, bottom grey rectangle.
Quote;
Although all of the above specifications can be met regardless of whether the BP26 preamplifier
is positioned immediately above or below the MPS2 power supply, optimum performance
will be achieved when the power supply is positioned above the preamplifier
BrysTony
« Reply #4 on: 6 Feb 2015, 12:42 pm »
When I had a BP-26 I tried it both ways and could not detect any difference.  I placed the BP-26 on top because I thought it looked better that way.  It will be fine either way you go.
Tony
alexone
« Reply #5 on: 6 Feb 2015, 06:56 pm »
Tony
...same here. no difference in sound at all. and yes, it looks better with the 26 on top:thumb:
al.
electricbear
« Reply #6 on: 6 Feb 2015, 08:37 pm »
Thank you all very much for your input.
Laundrew
« Reply #7 on: 6 Feb 2015, 09:10 pm »
Partial to the pre-amplifier on the bottom  :D
Be well...
alexone
« Reply #8 on: 7 Feb 2015, 09:45 pm »
...nice preamp the 26 - and i'd like to know when it will be replaced since it is there around 9 years or so which is a pretty long time for a preamp in the hifi world.
al.
srb
« Reply #9 on: 7 Feb 2015, 09:59 pm »
From ~ a year ago:
http://www.audiocircle.com/index.php?topic=124110.msg1307598#msg1307598
