SOLD: AKSA 100 Watt kitset
0 Members and 1 Guest are viewing this topic. Read 6553 times.
fred
« Reply #20 on: 24 Sep 2004, 02:37 am »
I can give you my perspective on integrating an AKSA into HT.  Assuming you're just getting started, I'll assume you have a HT receiver - or soon will.  This needs to have pre-outs - output from the internal preamp/processor which you'll use to feed your AKSA (front left and front right).
You may then notice that your center channel sounds a bit muddy - since it will not be amplified through an AKSA.  You may find it sounds better using the "phantom" mode to direct the center to L+R.  Eventually, you should get another AKSA amp .  Perhaps Hugh would be able to sell you a single channel version, but it may not be necessary in the long run if you plan to use 6 channels for your HT.
My setup includes a Yamaha receiver feeding 3 channels of AKSA.  Some day I'll add an additional AKSA for my rears (I just use 2 rears).
(Hugh - glad to hear it arrived.)
jjb
« Reply #21 on: 24 Sep 2004, 04:13 pm »
Fred, thanks. I do have an AV reciever it is a Marantz SR-19. I currently use the 2 of the pre-out's (L & R main) to divert the signal to my HSU-Research sub amp crosserover at 43hrtz, then it send the signal back to to the Marantz amp to the front mains. My amp also has a multi room connection which will divert the input source to an alternative amp. I may have to play with this set-up but I think I have something to work with here. I'm also think of selling my Marantz and purchasing an HT pre-amp like Parasound ) Geroge, I did not recieve the private email, I recently moved to another state, I will check and modify my profile, please resend tomorrow morning as I'm on-line at work (not allowed, little time). Jim
ctviggen
« Reply #22 on: 24 Sep 2004, 05:01 pm »
Thanks.  A VMPS sub is on my list of things to buy, and it would be fun to build an amp like the ASKA.  I could compare the ASKA with my Jeff Rowland (stereo duties), and I could also compare it to my Bryston 9B (surround duties).  Then, the "loser" would get to run the VMPS sub (or maybe two subs).
George W
« Reply #23 on: 24 Sep 2004, 09:46 pm »
Hi Jim,
I did not send you an email, but rather a "private message" through the audiocircle system.  If you look at the top of the page to the right of the Audio Circle logo, you'll see a bunch of links including one to check your private messages.  I could not find an email address in your profile, but I will keep checking in case you update it.
George
George W
« Reply #24 on: 25 Sep 2004, 10:16 pm »
Hi Jim,
Were you able to access the message?  Let me know if you would like to discuss or finalize the sale.
George
jjb
« Reply #25 on: 26 Sep 2004, 12:32 pm »
George, As luck would have it my wife's washing machine died on Saturday (it was smoking), my reserve fun money went to the new machine which arrives on Monday. It will be a few weeks before I can re-save rather than hold, If someone else is ready to purchase let them step you have a great produt at a great price. Jim:(
fred
« Reply #26 on: 26 Sep 2004, 05:04 pm »
JJB - I forgot one other issue with integrating the AKSA into a HT setup: a power relay. I choose to power up my AKSA whenever I turn on my HT system - rather than leave it powered up at all times, as many do.  If you make the same choice, then I recommend using a relay to perform the power switching.  The coil connection (the switch) is plugged into a switched outlet on my receiver, so powering on the receiver also turns on the AKSA.
The relay I use is an OMRON G7L-2A-TUBJ-CB, that I bought from MOUSER for about $12.  It is rated at 25 AMPS.  It's very easy to use; I can give you more details if you decide to go this route.
George W
« Reply #27 on: 26 Sep 2004, 10:53 pm »
Jim,
I am sorry to hear about your bad luck.  Thank you for letting me know quickly.
George
George W
« Reply #28 on: 28 Sep 2004, 12:04 am »
I really need to sell this soon so please see my post in the Trading Post for extra incentives and price reduction.
George
George W
« Reply #29 on: 30 Sep 2004, 11:00 pm »
The AKSA has been sold. Thanks everyone.
AKSA
« Reply #30 on: 1 Oct 2004, 12:34 am »
George,
I'm pleased you've been successful.   8)
I had a look at the gallery photos, and I have to say that from what I can see it was extremely well made.  The buyer should have no problems at all finishing it, most of the hard yards are done, and I'm confident he will be delighted with his new 100W AKSA.
Thank you for your explanation for the sale.  You made it clear that you were happy with the AKSA, and I appreciated that.  I hope things improve financially very soon......
Hugh
George W
« Reply #31 on: 1 Oct 2004, 11:17 pm »
Thanks Hugh,
I did a lot of reading up on the AKSA before I purchased, and have yet to hear of a negative review.  It was a bummer to have to sell, especially without getting to hear it, but perhaps one day I will be able to try again.  As an aside, I accepted a new job offer this morning so things are looking up.  Regards,
George
  • Speakers....What Speakers ?
« Reply #32 on: 2 Oct 2004, 03:37 am »
Quote from: George W
George W,
    Did you sign on to the audition tour for the AKSA ? You would then get to hear it... :dance: [/list:u]
George W
« Reply #33 on: 2 Oct 2004, 05:05 am »
I didn't sign up, but I thought about it while I was building.  To be honest, I'm not sure if I want to now, as I'm worried it will be too tortuous to hear what I cannot afford.  I'll also feel kind of guilty having the amp and making potential buyers wait for their audition.  I have no doubt it sounds great, and I don't think I will hesitate purchasing again having not heard it, when the time comes.
Thanks for the suggestion,
George
