***SOLD***Reference 3A MM de Capo BE monitors w/Factory stands
0 Members and 1 Guest are viewing this topic. Read 1337 times.
klipschfan
Reference 3A MM de Capo BE monitors (pair) with Reference 3A stands.
Current model less than two years old. Mint condition used in a second system.
From Reference 3A-
Description
At the heart of the MM de Capo BE is the hand built carbon fiber main driver. It is now even faster and better controlled.
The new high frequency unit is sonically more transparent and detailed than the original. It now has no ferro-fluids and a much lower resonant frequency. It now integrates even better with the main driver.
The cabinet dimensions are unchanged. Critical bracing points have been optimized to achieve an even more silent cabinet and less interference with the drivers.
The recent updates to the MM de Capo BE include a new beryllium tweeter which extends to 40 Khz, Surreal Acoustic Len on the driver cone to stop air vortex distortions, and the Nextel matte coated cabinet which reduces diffraction effects and absorbs surface vibrations.
Specifications
Sensitivity 92 dB
Impedance 8 Ohms
Frequency Response 42Hz to 40KHz
Power Handling 150 Watts RMS
Phase Coherent
Dimensions
Height 15" (38 cm)
Width 11" (28 cm)
Depth 13" (33 cm)
Weight 27 lbs (13 kg) each
Will only ship as explained below-
I do have the Factory box which is not in the best of shape, would need to be double boxed. Canadian winter did a number when I received them. I do not have the boxes for the stands.
Here is what I can do-
You would need to have a heavy duty box for the speakers and boxing of the stands along with shipping to you.....arranged directly with my local Fedex Office.
All costs handled between you & Fedex Office.
I will drop off the speakers/stands at the Fedex Office.
Speakers and stands are for pickup (Las Vegas, NV)...will only ship as explained above. Payment via Paypal. Plenty of feedback on the "Gon" under same user ID. Any questions, please PM-Thanks!.
Retail-$3,690.00
Sell-***SOLD***
« Last Edit: 5 Feb 2015, 11:26 pm by klipschfan »
klipschfan
Re: Reference 3A MM de Capo BE monitors w/Factory stands
« Reply #1 on: 4 Feb 2015, 04:01 pm »
Price
D
r
o
p
!... :thumb:
