Dummy load to burn in amp.
0 Members and 1 Guest are viewing this topic. Read 2110 times.
mikeeastman
« on: 1 Feb 2015, 02:45 pm »
I upgrade some of the wire in my amp and would like to burn it in but I can't have speakers playing 24 hr a day. I was told that I could put 8 ohm 5 watt resistor across either my speaker terminals or the end of my speaker cables to burn in the amp, will this work? Any down sides to this method?
Speedskater
  • Kevin
Re: Dummy load to burn in amp.
« Reply #1 on: 1 Feb 2015, 03:26 pm »
A 8 Ohm resistor - Yes.
A 5 Watt resistor No. Unless it's a very small SET amp.
A resistor gets very, very hot at it's rated power.
Most amplifiers get unhappy when operating continuously at 1/3 rated power. Read some of the Stereophile amp tests.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 1 Feb 2015, 03:29 pm »
You can use these.
Davey
« Reply #3 on: 1 Feb 2015, 04:43 pm »
Wire doesn't need burn in.  But if you want a nice, cheap dummy load find and old toaster and liberate the nichrome wire from it to construct a load.
Dave.
mikeeastman
« Reply #4 on: 1 Feb 2015, 05:45 pm »
Thank you all for your responses.  :thumb:
