Bryston Wireless Speakers - WiSA?
0 Members and 1 Guest are viewing this topic. Read 1126 times.
RonCH
« on: 22 Jan 2015, 09:25 pm »
Hi James,
What are your thoughts on Wireless Speakers and the WiSA standard?  In particular are you planning to make any?  A wireless active speaker seems to me something that would suit Bryston.
Ron
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Wireless Speakers - WiSA?
« Reply #1 on: 22 Jan 2015, 10:55 pm »
Hi James,
Ron
Yes we are looking at it as long as it can handle 192/24
james
BrysTony
« Reply #2 on: 23 Jan 2015, 01:14 am »
james
I would expect a wireless active speaker to receive an analog signal not digital.  What are you thinking in regard to this?
Tony
srb
« Reply #3 on: 23 Jan 2015, 02:04 am »
Low-power wireless analog audio signal transmission is very inefficient and is plagued with reception, noise and fidelity problems.
Consumer headphones and speakers I have listened to using this technology have all had unacceptable audio performance.
RonCH
« Reply #4 on: 23 Jan 2015, 08:29 am »
Take a look at http://www.wisaassociation.org/ and in particular http://www.wisaassociation.org/Compliance/Overview.aspx
The B&O Beolab 18 speaker use the WiSA Standard and they work well.
