Full Range Pictures
0 Members and 1 Guest are viewing this topic. Read 1794 times.
Full Range Pictures
« on: 19 Jan 2015, 11:38 am »
Eros 251V pro driver, V stand for voice.
DIÂMETRO NOMINAL    10    polegadas
DIÂMETRO FERRITE    169 X 18    mm
MATERIAL DO FERRITE    BÁRIO
DIÂMETRO DA BOBINA    2 1/2    polegadas
FORMA DA BOBINA    FIBERGLASS
ALTURA DA BOBINA    11    mm
ALTURA DO GAP    8    mm
MATERIAL DO FIO DA BOBINA    COBRE
SECÇÃO DO FIO DA BOBINA    ACHATADA
MATERIAL DA CARCAÇA    ALUMÍNIO
RESPOSTA DE FREQÜÊNCIA    60 ~ 6.500    Hz
SENSIBILIDADE (@ 1 W, 1 m) - FREE-AIR    96,03    dB/SPL
POTÊNCIA MÁXIMA (RMS)    200    W
POTÊNCIA MUSICAL    400    W
IMPEDÂNCIA NOMINAL    4 ou 8
RESISTÊNCIA, RE    3,2 ou 5,7    /Vcc
ÁREA DO CONE    0,0337    Sq.m
FREQÜÊNCIA DE RESSONÂNCIA    69    Hz
VOLUME EQUIVALENTE    21    L
Q MECÂNICO    10,3952    (Qms)
Q ELÉTRICO    0,2676    (Qes)
Q TOTAL    0,2609          (Qts)
PRODUTO BL    19,39    TM
NO (REFERENCIAL DE EFICIÊNCIA)    2,52    %
COMPLIÂNCIA (CMS)    130,42    uM/N
MASSA TOTAL (MMS)    40,65    g
MASSA DIAFRAGMA (MMD)    37,09    g
EXCURSÃO CONE SEM DISTORÇÃO (X MAX)    1,5    mm±
DENSIDADE DO FLUXO NO GAP    12.000    Gauss
