Ventilation Requirements?
0 Members and 1 Guest are viewing this topic. Read 7144 times.
jimdgoulding
Re: Ventilation Requirements?
« Reply #20 on: 20 Jan 2015, 10:14 pm »
I share everybody's reservation about your amp in a drawer.  But, my comment is about your room.  Way to go, dude!!  Beautiful it is.  For your benefit and anyone's, the backs of your speakers should be out a minimum of 3' off the wall behind them.  More is better especially if you listen to classical music or any music recorded on location.  The reason is dimensionality as tho you are seated in the audience.  You can then pick the row or your ticket to admission with your volume control.  Good listening to you.
sfox7076
« Reply #21 on: 20 Jan 2015, 10:32 pm »
I would drill holes in the bottom of the drawer (or routed louvers would be better), mount a fan over the holes, and have it push air up.  Not the most efficient way to do things, but it could word well.
BrysTony
« Reply #22 on: 21 Jan 2015, 12:41 am »
I believe you will have a heat issue because there is no air flow in that drawer, i.e, input and output.  Heat is the enemy of all electronics.  I am attaching a link to a reputable A/V cooling fan company.  Their fans are not expensive and will save you a headache later.  Call them up and describe your installation and get their input.  http://www.rackfans.com/pages/ProCooL_AV1/AV-180T.html
Tony
Laundrew
« Reply #23 on: 22 Jan 2015, 03:52 pm »
This is going to look simply awesome when finished and it would be great to post more photos during the construction phase up to completion  :thumb:
These amplifiers do produce a great amount of heat. In my situation, my amps are out in the open and I require a floor fan to keep my room cool during their operation. Another issue considering your cabinet is would the glue joints be affected with the heat from the amplifiers and would the wood be subject to warping? Keep us posted  :D
Be well...
BobRex
« Reply #24 on: 22 Jan 2015, 04:39 pm »
Umm, shouldn't you be more concerned with the distance from the front of the speaker to the back wall?  Dipoles and omnis excluded, that's where the sound is generated.
