VH Audio new product announcements.
0 Members and 1 Guest are viewing this topic. Read 1848 times.
ChrisVH
    • http://www.vhaudio.com
« on: 19 Sep 2004, 04:53 pm »
VH Audio is now offering deep cryogenically treated bulk Pulsar wire and finished Pulsar interconnects. .
We also now carry the WBT NextGen Eichmann Rca's and sockets in both gold and silver versions.
Other recent additions are: Belden Cat5 Teflon wire, Bybee Silver Slipstream purifiers, Furutech RD-2 disc demagnetizer, Furutech Schuko sockets and plugs, and the new formulation of Auric Illuminator.
For more information, or to place an order, please visit www.vhaudio.com
zybar
« Reply #1 on: 19 Sep 2004, 05:17 pm »
I can attest to the diference between the cryo'd version vs. standard of the Pulsar ic (I use it as my digital ic)
Here is what I told Chris:
Much larger and more spacious presentation (both L/R and F/B).
More snap and drive.  The whack of a snare drum is more detailed and pronounced.
Cymbals/bells have more shimmer and definition.
Spend the $10 bucks and get the cryo'd version.
George
nature boy
« Reply #2 on: 19 Sep 2004, 05:41 pm »
Chris,
Are you offering cyro treatment as an after market purchase option to those of us who already have the PULSAR IC's?  I could not find any info on your website.
Could you give me an idea of pricing for the following: a 4M pair PULSAR IC, a 1M pair PULSAR IC, a .5M pair PULSAR IC, & a 1.5M digital PULSAR IC.  A PM or response would be appreciated.
NB
shokunin
« Reply #3 on: 19 Sep 2004, 05:43 pm »
Chris,
WIll you be offering your manufactured Pulsars with the NextGen connectors versus the Eichmann's with the aluminum cover?  Thanks...
ChrisVH
NextGens
« Reply #4 on: 19 Sep 2004, 05:48 pm »
Quote from: shokunin
Chris,
It is likely, but I need to make a few sets up and test the strain relief. I don't like the NextGens having only one set screw vs. the Bullets two screws.
nature boy
« Reply #5 on: 23 Oct 2004, 01:01 pm »
Just a note to let fellow AC'ers know I have been using the cryo version of the VH Audio PULSAR digital cable in my modest HT setup for the last month.  George, thanks for the heads up on this.
A significant improvement: a wider and deeper soundstage/presenation as previously indicated.  Drums and stringed instruments more detailed.  Center channel vocals in my Vandersteen VCC-1 are clearer and fuller running them in the full speaker mode.  I'm getting even better integration with the VCC-1 and Vandy 2CE's.
A no brainer for the extra $10 per cord the Chris is charging.
I haven't decided if I'm going to get my 2 channel system VH Audio Pulsar's cryoed.  Cheers.
