Calibrate Your Level
0 Members and 1 Guest are viewing this topic. Read 1438 times.
neobop
  • BIRD LIVES
« on: 15 Jan 2015, 03:21 pm »
Here are instructions for calibrating an engineer's straight level.  These levels are adjustable, but with a little ingenuity you could apply these instructions for most any level.
http://www.leveldevelopments.com/wp/wp-content/uploads/documents/Engineers-Level-Calibration-Instructions.pdf
neo
Devil Doc
  • On the road to Perdition
Re: Calibrate Your Level
« Reply #1 on: 15 Jan 2015, 04:35 pm »
The problem here is you need something that is flat. Not an inexpensive item to acquire. The granite ones that machinists use aren't cheap and a 1/4" piece of tempered glass isn't quite adequate. The best soulution is to befriend a machinist and use his stuff 8) :
Doc
Devil Doc
« Reply #3 on: 15 Jan 2015, 06:58 pm »
Starrett's granite surface plates start at around $210. I wonder about the price discrepancy. Oh wait, Grizzly ain't exactly an industry standard. :thumb:
Doc
neobop
  • BIRD LIVES
« Reply #4 on: 15 Jan 2015, 07:54 pm »
Example 2 in the link tells you how to adjust the level even if the surface isn't level.
If you don't have a calibrated level you can still get it almost perfect.   Place the level on the surface and note the amount it's not level.  Turn the level 180° and see how the reading compares.  Adjust the level so you get the same reading both ways.  You can use thin shims under one end, or with some levels you can file down one end.   When you're checking the level make sure you put it in exactly the same place.
Epoxy putty is perfect for building up one end.  It is easily filed or sanded so you can get it just right.
neo
Hank
« Reply #5 on: 16 Jan 2015, 06:28 pm »
Doc, Starrett plates are hideously expensive.  Grizzly plates are fine - take time to look at the specs.
