Advice wanted - Magnepan .7 or Super MMG
0 Members and 1 Guest are viewing this topic. Read 4030 times.
JohnCZ
« on: 14 Jan 2015, 05:44 pm »
The .7 are probably too new to get any consensus opinion, however I'm looking to get opinions about which way to go. Cost being close on both what would be the advantage of either speaker. I do have a small 8 inch sub and larger 10 inch sub I could use for either system. Would probably use my Redgum RGi60 ENR or an Arcam receiver to drive the speakers. Any opinions? Thanks,
John
SteveFord
Re: Advice wanted - Magnepan .7 or Super MMG
« Reply #1 on: 14 Jan 2015, 10:39 pm »
What size room do you have?
JohnCZ
« Reply #2 on: 15 Jan 2015, 06:10 am »
Right now the room is 12 X 16 with 8ft ceilings. May later move my system to a slightly larger room. I generally do not listen to music loud. Most of the time its at low levels late at night.
John
brooklyn
« Reply #3 on: 15 Jan 2015, 06:51 am »
I have the MMG’s in a 11’ x 15' room with no sub and they sound great even at higher
sound levels. I think the .7’s are double the price of the MMG’s if that makes a difference.
SteveFord
« Reply #4 on: 15 Jan 2015, 09:32 am »
Figure keeping the speakers 4' out from the front wall and see where your listening position will be.
I'm guessing you'll have them on the shorter 12' wall.
If they're not going to be right on top of you I'd go big and look for some used 1.7s.
Failing that, I'd go with the .7s and I should mention that any of them will benefit from a subwoofer in the corner as they'll peter out around 40 Hz, give or take.
alexstl
« Reply #5 on: 1 Feb 2015, 01:53 am »
I do not see the price of .7 on line.  Do you know the price?  thanks, alex
brooklyn
« Reply #6 on: 1 Feb 2015, 05:55 am »
Here's a link to Magnepan for the .7
There web site doesn't list it but there priced at $1300.00
http://www.magnepan.com/model_MG_7
KKM
« Reply #7 on: 3 Feb 2015, 04:55 am »
Depending on what options you want the .7 range from $1400-1700:
http://www.audiolab.com/ProductDetails.asp?ProductCode=MAGMG%2E7
