Burson Conductor SL 1793 DAC/AMP with PREAMP
0 Members and 1 Guest are viewing this topic. Read 1370 times.
aboroth00
« on: 13 Jan 2015, 04:08 am »
Up for sale is my Burson Conductor SL 1793 DAC/AMP with preamp functionality in excellent condition (I never say mint or near mint, mint is new in box, and near mint, means I opened the box and never touched it) but the item looks pretty much new.  It sat on my desk for a month and went into the box.  The Burson was purchased from Parts Connexion, a Burson dealer and Burson's NA service/repair center and the preamp functionality was added by them as well which costed an extra 100$. The DAC was upgraded with a C-Media CM6631A 24bit 192kHz USB Receiver Module as well.  Also includes: RCA cable, USB cable, power cord, paperwork, box.
The Burson is equipped with the Burr Brown SL 1793 which I actually prefer over the ESS Sabre SL 9018.   I placed the Burson in my main setup with Revel Gem's and an ATI AT2000 amp and preferred it over my Oppo 105.  The Burr Brown was warmer, more musical and less edgy than the more analytical Oppo 105.  The volume control was great compared to the Oppo's digital volume control.
I'm only selling because I've moved on to a balanced setup with balanced outs of my speaker amp which is more of a priority to me.  It costed me nearly twice as much and i'm not even sure it's better...
The two-year warranty is NOT TRANSFERRABLE per Burson.  To guarantee that you get a fully functional unit, I have shipped it back to Parts Connexion for a full inspection on my dime and they will ship it to your address at no cost to you.
550$ includes PP and shipping to anywhere in Canada and US.  If you try to buy the same item from Parts Connexion, it'll cost you 720$ (600$ for the amp, 100$ for the preamp upgrade and 20$ for shipping).  So you can save 120$ here and have a pretty much brand new amp shipped from the factory as well.  I don't have as much feedback here, but I have 100% feedback on Audiogon, ebay, AVSforum, Emotiva forum, audiocircle, usaudiomart, and Polk Audio forum, under the same username so buy with confidence.
More tech specs:
Measurement
Input impedance: 36.5 KOhms Frequency response: ± 1 dB 0 – 50Khz Signal to noise ratio: >96dB THD: <0.03% at 30ohm with 1W ouput Channel separation: >73dB Output power: 4W at 16 Ohms Input impedance: >8K Ohm @ 30 Ohm, 1W Output impedance: 45W, internal, regulated power supply
DAC Specification
Channel Separation: 140 dB @ 1KHz, 130 dB @ 20KHz THD+N: 0.0005% @ 1KHz, 0dBFS COAX & Toslink / SPDIF : 32 bits / 44.1K, 48K, 88.2K, 96K, 176.4K, 192KHz
USB Specification
OS Requirement: Windows XP, Windows Vista, Windows 7, Windows 8, Mac OS X USB : 24 bits / 44.1K, 48K, 88.2K, 96K, 176.4K, 192KHz Support up to 24bit @ 192Khz with 10ppm low jitter clock Asynchronous Transfer Mode
Inputs
1 x USB Connection 1 x Coaxial RCA (Support up to 24bit @ 192Khz) 1 x Toslink / SPDIF (Support up to 24bit @ 192Khz) 2 x RCA line level input
Outputs
1 x headphone jacks 6.35mm
General
Weight: app. 3 kg Colour: silver anodized aluminium Dimensions: 210 x 220 x 80mm
Package Content
1 x Conductor SL Headamp 1 x Power cable 1 x RCA pair input cable 1 x RCA Coaxial cable 1 x USB cable 1 x User Manual (including 24 months warranty registration information)
