FireFox 34 Bug - Help
0 Members and 1 Guest are viewing this topic. Read 1376 times.
« on: 9 Jan 2015, 11:48 pm »
The Chinese characters are part of a favorite, they appear on the monitor 1 when I see videos on the monitor 2.
Any solution?
jmc207
Re: FireFox 34 Bug - Help
« Reply #1 on: 10 Jan 2015, 12:24 am »
The McAfee SiteAdvisor extension has been reported to cause this. Disable it and see if that helps.
https://support.mozilla.org/en-US/questions/1034692
https://support.mozilla.org/en-US/questions/1035523
srb
« Reply #2 on: 10 Jan 2015, 12:27 am »
If it turns out not to be the McAfee Site Advisor extension, you can often troubleshoot problems like this by restarting Firefox in Safe Mode.
Help > Restart with Add-ons Disabled
Firefox will close and present a dialog box - Select Restart in Safe Mode (Do not select Reset Firefox).
If you're able to view normally there is likely a problem with another Add-on Theme or Extension.  You can then disable Add-ons one by one and perhaps find the culprit.
Your screen resolution is likely wider than many other users (> than 1366) and requires scrolling.  Consider uploading smaller width photos if the additional width adds no usable information.
« Reply #3 on: 10 Jan 2015, 04:31 pm »
Prob solved! Thanks guys you are the best. :thumb:
« Reply #4 on: 16 Apr 2015, 01:27 am »
The problem kept happening sporadically.
Then one day I noticed there was a huge amount of .db files scattered in folders, including in the work area.
The files were thumbs.db and other similar names, after a long manual inspection in all folders FF cameback to normal.
So some months after at end of a google work, I saw the Mr.G in action doing sabotage in FF at my PC.
The .db files were illegally installed on my PC by Google.
The files contain programing, tags and a long plethora of FF favorites details.
