FS: Pair of Mahogany fonken-style single driver monitors
0 Members and 1 Guest are viewing this topic. Read 1997 times.
RickRichardson
This is a beautiful pair of fonken-style single driver monitor speakers, perfect for low powered SET amps or chip amps.  This pair of speakers is mahogany and uses the HIEND 4 NEO full range driver with neodymium magnets, offering exceptional speed and control.  The results are a highly coherent, detailed sound, exceptional tonal quality and surprisingly good bass down to about 55 Hz.
You can get more info on cabinet design from Planet 10 Audio, a Canadian company specializing in horn designs.  The original “Fonken” cabinets were made for the Fostex FE127e.  I believe this pair originally had the FE127e drivers and a previous owner replaced them with the present drivers.  A discussion of the Fonken name can be found at http://www.diyaudio.com/forums/planet-10-hifi/160747-fonken-style-box-nomenclature-what-those-names.html
For a small to moderate size room, these will work great.  If you need to rock the bass, throw in a small subwoofer.  Each speaker is 9 ½” W x 11”D x 14 ½” H and weights 18 lbs.  Total package weight will be about 46 lbs.
Although these cabinets may have been designed for a Fostex driver, I believe they sound excellent with the current drivers and might also work with other full range drivers, from Fostex, Mark Audio or whoever.  I would encourage the new owner to experiment if they are of a mind to do so.
    I am asking $385 plus shipping.
« Last Edit: 27 Jan 2015, 06:17 pm by RickRichardson »
RickRichardson
Price lowered to $385
« Last Edit: 27 Jan 2015, 06:20 pm by RickRichardson »
RickRichardson
Re: FS: Pair of Mahogany fonken-style single driver monitors
« Reply #2 on: 27 Jan 2015, 06:21 pm »
Bump - still available
