Very basic JRiver question
0 Members and 1 Guest are viewing this topic. Read 2642 times.
PHamm
« on: 5 Jan 2015, 07:04 pm »
Please excuse the very basic nature of this question, but I'm still trying to get my head around the terminology and nature of JRiver. I recently installed JRMC for Mac 20 on my headless Mac Mini and it worked well enough. However, I subsequently had to replace the external hard drive which holds all my music files. This prompts a simple question: how do I re-point my JRMC audio library to the music files on the new hard drive? There must be a very simple way to do this, but I can't seem to find it on the JRMC wiki or forum. I assume someone here will know the answer. Again, I apologize that this question is so basic.
Big Red Machine
Re: Very basic JRiver question
« Reply #1 on: 5 Jan 2015, 07:52 pm »
On the main menu along the top, you need to get to Options (inside one of those), then along the side there are quite a few menus to choose from.  While at work I cannot remember, but one of them asks for your drive.  As a side note, I use 3 drives and in my menu only 2 are shown but the software finds them all eventually.  it is pretty good s/w.  The more you use it, the more you see how flexible it is.  I have been using the Add to Playlist function quite a bit to keep building a compliation of the tracks that demo my system the best.  You can do this while playing any track.
Big Red Machine
« Reply #2 on: 5 Jan 2015, 07:54 pm »
Tools menu along the top, start there.
Phil A
« Reply #3 on: 5 Jan 2015, 08:30 pm »
I'd think you would want to go to 'file' on the upper left and then to 'library' and then import your music.    You can configure the import to do multiple drives.  http://wiki.jriver.com/index.php/Import
PHamm
« Reply #4 on: 6 Jan 2015, 02:21 am »
Thanks, guys. This sort-of solved the problem. I tried the Tools/Library/Import approach and re-loaded all the files, but I also now have two copies of each track--one with a file path to my old hard drive and one with a file path to the new drive. This is a bit of a nuisance and will require some serious editing at some stage, but I can play music via JRMC again. At least this is better than my original if-all-else-fails plan to deleting my library and reinstalling it because I didn't lose cover art. I hope this question is helpful to other new users of JRMC. Cheers.
Phil A
« Reply #5 on: 6 Jan 2015, 04:02 am »
I store the cover art with the albums (so if I back-up stuff it is there).  You can go to 'file' on the upper left and clear the library.
Phil A
« Reply #6 on: 6 Jan 2015, 04:04 am »
You can go to 'Tools' and then 'Options' to dictate where the cover art goes.
Vincent Kars
  • The Well Tempered Computer
« Reply #7 on: 6 Jan 2015, 07:06 pm »
Not really.
Assuming the OSX interface is like the Win:
-select all the albums
- open the file panel
- sort by filename
Now you can select all the files on the old drive and delete them.
Next time: if you move to a new drive simply use Library Tools > Rename Move Cope and chence e.g. C: to D:
PHamm
« Reply #8 on: 6 Jan 2015, 07:42 pm »
Wow, that was simple! Thank you, Vincent!
Paul
Vincent Kars
« Reply #9 on: 6 Jan 2015, 07:56 pm »
JRiver is very feature rich hence it takes some time to find your way.
Maybe my website is of use to you as it list a couple of JRiver's options: http://thewelltemperedcomputer.com/SW/Players/MC14/MC14_intro.htm
