0 Members and 1 Guest are viewing this topic. Read 11703 times.
Check out the thread above: "Getting Started ..." from JohnR, a very good step-by-step tutorial when you're ready to start ripping CDs.
I thought I could drop vinyl and go digital , I even purchased a decent Dac but my table just has a sound I cant get from a DAC so I decided to keep both
+1That is very good information. I read it before I began ripping my CDs - and I'm mighty glad I did.
It's entirely dependent on the gear in each category being used. I have seen my preference go back and forth as particular components have been changed/upgraded. When every category is optimal, vinyl will still rule. Surface noise on vinyl does not have to be an issue. With my current set-up, it's almost non existent. My two digital sources are superb, but vinyl is still the best (wasn't always so, at least for me.) After having many combos, including a Mac Mini and many fine DAC's, I do not believe a computer/usb cable/DAC is the best way to go. I love my 2 digital sources, and enjoy them greatly. The connivence factor can not be overstated. The Oppo/Modwright player gives me the ability to play CD's (of all formats) from my own collections as well as the ability to enjoy discovery at my local public library which has resulted in many purchases. I respect copyrights. My Lumin NAS player is a delight. I wouldn't give up any of them! My system: Speakers: SoundLab U-1PX Amps: Ayre KX-R pre, MX-R monos, ARC REF PH2SE phono. Digital:Lumin A-1 NAS Music Sever, Oppo105/ModwrightTruth Player. Analogue: SME 20/2 table, SME V arm, Koetsu Rosewood Signature, Sumiko Celebration. Power&PC's: 3 Dedicated AC lines, Shunyata Triton/ 3 Typhons, and numerous Alpha PC's. IC's: Skywire XLR and speaker cables. Tweeks: Stillpoints Ultra 5's & SS's throughout. 2 LPI's, cable lifters.
I should add that the Mac Mini is as good as most other computer choices, assuming you are running iTunes. If so, there are additional steps that should be followed. HighRez is a whole new game.
Computer is enough suitable thing for music listening. There are matter of simple user intefface + remote control of used soft.Audio streamers is attempt do it. There removed all excess that inside computer.Audio quality depend on used DAC and software.LP is other ideology. This is not best (sound quality) source. It has own sound, mechanical ("non virtual") moving parts - it interesting from aesthetic point of view. Same about tape.
