12 volt trigger cable
0 Members and 1 Guest are viewing this topic. Read 2179 times.
harley52
« on: 27 Dec 2014, 08:14 pm »
 Anyone have any idea where I might find these? What I need goes between components to turn on. I've checked the well known places, PE, Mono price and others with no luck. Would these be called something else that I'm not aware of? I did find something like it at Amazon but, only three feet long.
Wayner
Re: 12 volt trigger cable
« Reply #1 on: 27 Dec 2014, 08:31 pm »
Aren't they just 3.5mm mono cables? The components that I have use that......3.5mm connector at each end and your choice of lengths.......http://www.amazon.com/3-5mm-Mono-Male-Cable-Plated/dp/B004HZR2OG
Phil A
« Reply #3 on: 27 Dec 2014, 08:34 pm »
When I had Bryston amps with other equipment, I just made a cable with the mini-jack at one end and the two wires at the other.
jparkhur
« Reply #4 on: 27 Dec 2014, 08:35 pm »
It's just a head phone cable.  Go to bbc or radio shack.
harley52
« Reply #5 on: 28 Dec 2014, 03:56 am »
Well, apparently I've been looking for the wrong size. Thought it was 2.5mm. 3.5mm is easy.
Appreciate greatly guys.
