***SOLD***:Clear Image T4 Special Edition Power Conditioner
0 Members and 1 Guest are viewing this topic. Read 604 times.
Lak
***SOLD***
This Clear Image T4 Special Edition works very well and is in good condition.
The Special Edition new sold for over $3000.
Asking $999.00 or best offer.
According to Byron Collett (the manufacturer) only three of the Special Edition T-4’s were ever made, hand build by him, one for his personal use and two for special customers.
The chassis and components are found in the regular T4 however all wiring in the Special Edition is 14 gauge Acrotec 6nines wire.
This unit also has the AudioPrism ACFX that pre filters the input power and superior switch-breakers were used.
There is a custom hard wired 7’ power cord on the Special Edition that was made by Kimber Kable.
This unit uses four separate isolation transformers and a separate set of filters for each outlet.
Each output has a line voltage phase reversal switch with an off position.
Each outlet is designed for audio source or video equipment loads up to 250 volt / amperes continuously 12 a for 115v models.
Each outlet may typically be used for stereo power amplifiers up to 40 watts per channel or up to 80 watts for mono-block amplifiers.
I only used this unit for front end equipment such as preamps, CDP, Tuner, Turn Table etc.
5 1/4” H
18” W
15 1/4 D
Add 1/2” for feet H
Add 1 1/2” for handles D
57 lb.
Comes with original heavy duty shipping box.
Buyer Pays shipping, insurance and 3.1% PayPal fee.
Checkout my feedback on Audiogon, my user name is Lak. Feel free to contact me through this site or the Audiogon site.
I have not used the T-4 in quite a while because of my current power filtration system that is permanently set up in my home. It’s time someone else enjoy this unit.
I believe as stated above the T4 Special Edition has a Copper clad chassis, balanced filtration (hot & neutral) w/ custom toroids and EMI modules made by CORCOM. The switches are also breakers (aircraft grade), there's polarity reversal for each filter and the transformers are damped. The special edition uses an integral Kimber power cord, better wiring and switches plus an ACFX circuit mounted on the front.
« Last Edit: 6 Jan 2015, 04:53 pm by Lak »
