Modwright Tube Hours
0 Members and 1 Guest are viewing this topic. Read 1680 times.
stump4545
« on: 21 Dec 2014, 02:42 am »
Can anyone tell me home many hours do the stock tubes last in the Modwright:
36.5
36.5 seperate power supply
Modwright PH 150 phonostage?
thank you
Phil A
Re: Modwright Tube Hours
« Reply #1 on: 21 Dec 2014, 05:18 am »
I have a 36.5DM for several years.  I substituted most of the factory tubes (rectifiers and 6H30s).  I'd think they would last several thousand hours under normal usage.  Don't know about the phono stage
stump4545
« Reply #2 on: 22 Dec 2014, 12:36 am »
Do all tubes in the modwright 36.5 and separate power supply last about the same hours?
Is swapping the stock Modwright tubes to others a big upgrade or personal preference?
thanks
Phil A
« Reply #3 on: 22 Dec 2014, 04:20 am »
I found them a nice upgrade. I also upgraded the fuses (Synergy HiFi).  I would not call it night and day but a nice upgrade.  I got the (Create) Synergy Hi-Fi 5AR4s too.  Do a search here - there are threads about their tubes and reviews at 6 Moons.  Not horribly price at $80 each.  I also put their 12AU7s in another (Odyssey) preamp in a secondary system.
Phil A
« Reply #4 on: 22 Dec 2014, 04:23 am »
Here some posts about the (Modwright) preamp tubes on another forum, FYI - http://www.whatsbestforum.com/showthread.php?10874-6H30-tube-life
Note that one guy replaced them after 6,000 hours
