TV/Movie audio rig recommendations....
0 Members and 1 Guest are viewing this topic. Read 1893 times.
decal
« on: 19 Dec 2014, 06:18 pm »
Looking for some recommendations for a TV rig consisting of a powered sound bar and universal player. Let's say a max budget of $1000.00 and very user friendly.
Bob in St. Louis
Re: TV/Movie audio rig recommendations....
« Reply #1 on: 19 Dec 2014, 07:51 pm »
Just to confirm, you're looking for TV, Player, Sound bar and cables for a grand?
stlrman
« Reply #2 on: 19 Dec 2014, 09:45 pm »
I would think that would be really easy to do at under a grand.  50 inch Plasmas cost nothing these days.
Phil A
« Reply #6 on: 20 Dec 2014, 05:16 am »
The Oppo is a great Blu-Ray player.  I have two 103Ds, one in the main system and one in a secondary system.
decal
« Reply #7 on: 20 Dec 2014, 01:36 pm »
I think the Oppo is a shoe-in. Anybody have any experience with the Vizio set-up?
Doublej
« Reply #8 on: 20 Dec 2014, 01:51 pm »
Not the exact Vizio models you are looking at...
http://www.soundandvision.com/content/top-picks-soundbars-and-home-theater-box
Quiet Earth
« Reply #9 on: 20 Dec 2014, 02:30 pm »
I really like our ZVOX sound bar. I bought the second to the smallest one that they make because it fits perfectly on the shelf right under my TV. It is plenty loud and clear, and it sounds a lot better than some of those plastic soundbars that you see at the big box stores. ZVOX cabinets are made out of wood, not plastic.
Price is good too. Simple black box that sounds good and disappears in the room. Here is the model I have:
http://www.zvoxaudio.com/divinity-cart/item/4003201/zvox-audio-soundbase.320/1.html
jarcher
  • It Just Sounds Right
« Reply #10 on: 21 Dec 2014, 10:36 am »
The oppo 103 is a no brainer. I'd pony up extra for the darbee edition - it's worth it.
In a soundbar the Sonos playbar is decent, well made, and very easy to set up.
The cost for both will take you over $1k, but I think it will be worth it.
