0 Members and 1 Guest are viewing this topic. Read 2386 times.
When I try to configure the receiver for input from the TV I get three choices of "Fixed Mode": 1 off, 2 PCM, 3 DTS Since the TV output is PCM I set the receiver to that. I think I also tried off but not sure if I tried it in combination with Dolby out from the TV. It really is a slog switching back and fort trying all the combinations. What mode do I need to use there?
Steve, I set the receiver fixed mode to off and the TV to Dolby like you suggested. I only get two channel audio. Will it be like that for all TV broadcasts or did I just pick a couple of 2-channel broadcasts to test?
On another receiver menu I had choices for Dolby and DTS. I chose "Straight Decode". Was that correct?
I had a center signal using All Channel Stereo but as you pointed out it is an L R mix. Does that maintain the L and R channels discreet? I am curious even though it is a somewhat moot point.
I scrolled like you suggested. I was able to get a center channel from the TV in the following modes: Direct, Dolby Digital, and Theater Dimensional among others. I am assuming Dolby is the correct choice. Right? What the heck is "Direct"?
