New music group. The Skinny 6's and the Flat 5.
0 Members and 1 Guest are viewing this topic. Read 10364 times.
Danny Richie
« on: 16 Dec 2014, 06:11 pm »
More like new models really. I have been working on a new pair that will have a matching center channel. But the three piece line up will be quite the music group.  :thumb:
The Skinny 6's are going to be great speakers for two channel or home theater applications. These image like crazy and will present a great sound stage. They will also be ideal for small rooms or untreated lively rooms. Full range driver guys will love them too.
The top LGK driver is covering an extremely wide band. It's in a sealed box. The four below it are in a ported box and are covering mid and low bass. On the back side is another LGK driver in the top of the box. This one is covering some of the upper ranges only and adds a layer of realism and spacial cues to the sound stage.
At first I tried what I tell everyone not to do. I let the drivers cross in the mid-range with a crossover point of 400Hz. They were identical drivers after all and the response curve looked good. It didn't sound good though. The 8mH laminated iron core inductor caused enough smearing to really muddy up the mid-range. So they went back to the drawing board. Going to a 12mH Erse Super Q inductor on the lower drivers and following it with a larger cap pulled the lower woofers back to a crossover point just over 300Hz and added a steeper slope that got them out of the upper ranges. And the result was that the great mid-range that the LGK drivers excel at so well shined through just like the little LGK 1.0 model. After putting them through their paces they get a thumbs up now.  :thumb:
The bass response is really tight and clean and they handled low frequency hits from the Chinese drum tracks pretty well. They seemed really un-bothered by the low notes while popping out solid mid-bass hits. -3db down points are in the low 70's. Even with just 1/2" thick material the side panels never moved, flexed, or resonated with bass notes. They are well braced and lined with No Rez. But I was still surprised by how solid they were.
Sensitivity is 87db and they are extremely smooth (+/-1db all the way to 5kHz).
Even with the rear firing driver these can be used in close placement to the front wall. The rear driver doesn't play low enough to cause coupling issues with the wall.
For those of you thinking you can just mount a full range driver on the front and on the back of a speaker like this and this it will work out great, you are mistaken. As wavelengths increase they wrap around the enclosure and become more omni directional. Then the output from the front and rear drivers arrive out of phase and cancel each other out making large dips in the response. And running the rear driver out of phase just shifts the cancellation to another spot. It is not the same as a single open baffle driver.
The only way this works is to limit the range covered by the rear facing driver. It has to cover only the frequency range that will have wavelengths short enough to not be able to become omni at all, or have any output to the front of the speaker. So all of its output is reflected energy from the front wall. And it does have quite the effect on things. It gives the effect of musically instruments being in the room with you rather than coming at you from a speaker. So they add the realism that you get from a lot of open baffle speakers.
As soon as I can I'll start on the matching center channel. The Flat 5 will be a five driver array that will be much like the forward facing drivers of the Skinny 6's. It will put the main wide band driver in the center and have the two low range covering drivers on each side of it. It will likely have a forward facing port on each end too. It will be a short (flat), wide, and deep box design.
I think you guys are really going to like these.
randytsuch
Re: New music group. The Skinny 6's and the Flat 5.
« Reply #1 on: 16 Dec 2014, 07:02 pm »
First question that comes to mind is how would these sound compared to the Wedgie?
These must go lower, but figuring you need a sub anyway.
Also wondering what the dimensions are.  Since the LGK is a small driver, I have a feeling they are smaller than they appear in the pics.
Also wanted to say I love my LGK's.  I have them setup for nearfield on top of my desk with a subwoofer for the low end, and they sound great.
Randy
Vedder323
  • vinyl reviews and more, check out Newrecordday.com
    • New Record Day
« Reply #2 on: 16 Dec 2014, 07:20 pm »
Love it!
persisting1
« Reply #3 on: 16 Dec 2014, 09:38 pm »
What are the dimensions of Skinny 6 and the Flat 5?
oz_audio_todd
« Reply #4 on: 16 Dec 2014, 11:03 pm »
May be I am missing the point, but wasn't there talk of 4 LGK's with an actual tweeter that had like 94dB's of sensitivity?
randytsuch
« Reply #5 on: 16 Dec 2014, 11:12 pm »
Maybe the Wedgie I referred to?  It has a ribbon tweeter.
http://www.audiocircle.com/index.php?topic=126112.0
Danny Richie
« Reply #6 on: 16 Dec 2014, 11:47 pm »
Very different speakers. The Wedgies have high sensitivity and a higher dynamic range that really separates them. They also have the added resolution of the planar magnetic tweeter.
See cabinet plans:  http://gr-research.com/pdf/skinny%206%20box.pdf
 :thumb:
Danny Richie
« Reply #7 on: 16 Dec 2014, 11:48 pm »
I still need to draw out the Flat 5. I just posted the cabinet plans for the Skinny 6's though.
Danny Richie
« Reply #8 on: 16 Dec 2014, 11:49 pm »
That's the Wedgie. It's incredible. A bass section and a taller full floor standing version is coming too.
mlundy57
« Reply #9 on: 17 Dec 2014, 01:12 am »
I'll second that!
Mike
ebag4
« Reply #10 on: 17 Dec 2014, 02:10 am »
Third!! :thumb: :thumb:
Peter J
  • Hmmmm
« Reply #11 on: 17 Dec 2014, 02:17 am »
Hi Danny, nice to see this project come to fruition...sounds like a success! How about that, I made a pun...
For anyone that's interested, I can email you the Sketchup model to play with if you like. PM me.
Danny Richie
« Reply #12 on: 17 Dec 2014, 04:25 am »
I just wish I could have jumped on it sooner.
And fellows. Peter J made the test cabinets. And he did a great job.
oz_audio_todd
« Reply #13 on: 17 Dec 2014, 05:08 am »
Not the Wedgies,
7th dec 2013 Post by Danny:
"It would be a thin three way design. You can do a T26SG tweeter in the center. It has high sensitivity."
(not the full post, but that is the guts of what I was thinking of. In the Desktop speaker thread)
oz_audio_todd
« Reply #14 on: 18 Dec 2014, 12:52 pm »
wow, I kinda feel like I killed this thread!  :/
oz_audio_todd
« Reply #15 on: 31 Dec 2014, 06:24 am »
So would this concept not be more effective with the T26SG tweeter, with the increase in sensitivity and probably off axis response too?
Couldn't you just sell the 4xLGK stand/bass box section with the required x-over for the ppl that do want to augment their single drivers?
Danny Richie
« Reply #16 on: 1 Jan 2015, 05:48 pm »
If a single LGK were used then the sensitivity would be the same. Off axis response in the top octave would be better with the tweeter. However, for small sized or untreated rooms that might not be a plus.
Yes, it could be made modular, but the crossover (or filter) for the upper driver changes when the lower four drivers are added.
rjryan
« Reply #17 on: 1 Jan 2015, 08:30 pm »
Very nice :thumb:
oz_audio_todd
« Reply #18 on: 2 Jan 2015, 06:32 am »
Actually, I was thinking of the MMTMM concept with that tweeter (if that makes it more exciting to anybody  :)  )
Danny Richie
« Reply #19 on: 2 Jan 2015, 04:07 pm »
That might be interesting.
