FS: Muse Mini USB DAC (black) $20 shipped
0 Members and 1 Guest are viewing this topic. Read 3248 times.
kgturner
« on: 16 Dec 2014, 12:04 am »
Sold on eBay
I bought the wrong DAC. I needed one that is powered by a wall wart and not by the USB. My mistake. Figured I'd give it a go here before I put it back on eBay. These sell for ~$25 on eBay shipped from China. I'm right here in the USA. The photos below are of the actual unit I received today. Here are the specs/info below are cut and pasted from the eBay seller:
Muse PCM 2704 Mini Digital Sound Card Audio Adapter HIFI USB to Coaxial S/PDIF Converter Optical Coaxial Decoder Analogue Signal USB DAC Chipset with USB Cable
 Product Features
· Full-featured, with analog output, coaxial / optical digital output, headphone output, you can output to the headphones, directly as a USB sound card to use
· Digital output signal isolation transformers fever DV709 digital filter, the other a more pure sound
· Coaxial and fiber optic signal IC for high-speed data through the plastic, the output signal is more stable, pure.
· With fever world acclaimed USB chip PCM 2704
· Compact, portable, includes input and output sockets
· Comes with a headphone output for private audio listening.
· Powered by USB cable, so there is no need to install on wall or batteries to worry about.
· Uses it standard or build right into your DAC. Operation and setup is plug-and-plug, no drivers to install.
· Use of safe and reliable USB B type port, to send high-quality USB cable, without power, plug and play.
· The surface of the expensive laser engraving fonts, never fade.
· Enable you to output to the amplifier, an integrated sound card as a computer upgrade products, can be connected to the decoder, will be sent back to the best level of sound quality.
· Compatible with both Windows XP and Mac OS-X. For best playback in Windows
· Provides the easiest way to convert your PC into a hi-end music server. Join the hundreds who have already upgraded. Once you get used to playing CDs from your computer, you'll never want to go back to a traditional transport.
Specification:
Voltage: 5V
Distortion: THD+N: 0.006% (RL > 10 kΩ)
SNR: 98 dB
Output Power: 12 mW (RL = 32 Ω)
Sampling Rate: 16Bit 32k, 44.1k, 48k
Package:
1 x Main Unit
1 x USB Cable
« Last Edit: 20 Dec 2014, 12:43 am by kgturner »
asliarun
Re: FS: Muse Mini USB DAC (black) $20 shipped
« Reply #1 on: 16 Dec 2014, 12:19 am »
On a side note, it looks like this is powered by a wall wart. The coax and optical inputs  would definitely need a power source.
kgturner
« Reply #2 on: 16 Dec 2014, 12:32 am »
There's no place for a wall wart. The ad copy implies that it's powered by USB. I already packed it back up after taking the pictures. I might pull it out later just to test it out and see if the USB really does power the optical input.
Kevin T
srb
« Reply #3 on: 16 Dec 2014, 12:35 am »
The coax and optical jacks are outputs, not inputs.  This would also allow it to be used as a USB to S/PDIF converter.
kgturner
« Reply #4 on: 16 Dec 2014, 12:44 am »
Hell....then this thing was all wrong for what I wanted to do.
Doublej
« Reply #5 on: 16 Dec 2014, 01:13 am »
What are you trying to do? Muse has a few different models.
kgturner
« Reply #6 on: 16 Dec 2014, 01:19 am »
Run optical out from my music server housed in a theater closet to a DAC connected in my main stereo rack. I'm searching for my final DAC (leaning towards Line Magnetic), but I just need something cheap and easy to make due until then.
Kevin T
thunderbrick
  • I'm just not right!
« Reply #7 on: 16 Dec 2014, 05:19 am »
If those are outputs, why are the RCAs labeled "audio out?"   :scratch:
barbarous
« Reply #8 on: 16 Dec 2014, 05:44 am »
Presumably the device passes a digital signal through the coax and optical jacks (ie not audio signal) and line-out through the headphone and RCA jacks (audio signal). Again presumably the audio output volume would be controlled on the computer.
srb
« Reply #9 on: 16 Dec 2014, 06:48 am »
They're all audio signals.  The RCA line-out and headphone jacks output DAC-converted analog audio signals and the optical and coaxial jacks output S/PDIF digital audio signals.
charmerci
« Reply #10 on: 16 Dec 2014, 07:19 am »
Kevin T
I'm fairly certain that the USB, Optical and single yellow coax connectors on that one side are all inputs. (But I have been known to be wrong before!  :roll: )
srb
« Reply #11 on: 16 Dec 2014, 02:58 pm »
I also have been known to be wrong before, but according to the listing:
Sure sounds like digital outputs to me, unless there's some kind of software to toggle between input and output function.
kgturner
« Reply #12 on: 20 Dec 2014, 12:42 am »
Sold on eBay
