iTunes as Source
0 Members and 1 Guest are viewing this topic. Read 1732 times.
lextek
iTunes as Source
« on: 13 Dec 2014, 01:56 am »
I started years ago with vinyl, that's all there was, cassettes and CDs.  I've been just buying from the iTunes store because it's so easy. Trying Tidal, not sure yet.  So  my question is iTunes a good alternative as a source?  Also using Audivarna or AppleTV with Cambridge Audio DAC.
jarcher
  • It Just Sounds Right
Re: iTunes as Source
« Reply #1 on: 13 Dec 2014, 02:36 am »
If you're using a Mac, suggest getting a player that works on top of iTunes such as Pure Music or Audiovarna for better sound quality.  You can go to their respective websites to download trials.  You can still use the free Remote app for your i-devices to control iTunes w/ these players on top.
If you're using a PC / Windows, then J River Media Center 20 will offer support for more formats (e.g. FLAC, DSD, etc) than iTunes.  You can control JRMC w/ a tablet buying the Jremote program ($10).  I don't think JRMC is that expensive either & you can try before you buy.
There is JRMC 20 for Windows as well & it's worth trying as an alternative to iTunes.  It's very stable and responsive and will sound better than iTunes, but not sure it sounds better than Pure Music or Audiovarna.  If you like how it sounds though, it's ultimately a better alternative than iTunes.
I wouldn't use an Apple TV as a go between - either hook the DAC directly to the computer using USB, or if you must go wireless, use an Airport Express (via minitoslink optical) that is bit perfect (Apple TV up samples to 48hz and audibly messes up the sound).
I have to say though that if you don't already have a large pre-existing music collection and plan or want to listen to a lot of material new or old, then going for a CD quality service like Tidal or Deezer makes a lot more sense.  If I didn't already have a very large music collection, that's what I'd do.
« Reply #2 on: 13 Dec 2014, 10:57 am »
Yes iTunes is MP3 quality (less than CD, otherwise known as "Redbook," which is the defacto minimum audiophile quality standard).  MP3 is great for portable use (compared to cassettes) and saves significant storage space (but beyond portable use storage is cheap/easy nowadays unless you have over say 6,000 albums and don't want to do loseless compression).
I'm still semi-old school.  I listen to internet streaming and ripped CDs via ALAC (Apple loseless format) on iTunes.  But the day is approaching when I'll have to buy my music via download.  I don't have serious interest in hi-resolution formats (at least until the "arms race" settles down), so for now the plan is to use a MacBook Air (with 256 GB of flash memory) as source/control via a Halide Design DAC ($500 with 5 meter of tethered USB input/RCA output cables with a yet to be determined software upgrade to iTunes.
« Last Edit: 16 Dec 2014, 10:28 am by JLM »
lextek
« Reply #3 on: 14 Dec 2014, 12:25 pm »
Thanks for the input.  I am using Audivarna with the MacBook.  I tried comparing CD vs. iTunes/Audivarna vs. Tidal/AppleTV.   Same playlist. All ran through the Cambridge DACMagic.  Maybe my ears aren't what they used to be, but they all sounded pretty, close.  Slight nod to the CD.  I've also tried the Airport Express.
     So it looks like I might use Tidal for discovery, buy CDs (used) and rip.
I guess there's always vinyl.........
