0 Members and 1 Guest are viewing this topic. Read 6004 times.
My confusion lies in the baffle dimensions. As you said to look around, I have and am confused. Are there set values? Like a certain amount of surface area, or square footage yields certain baffle rolloff? Or it seems more that the distances from the driver to each edge decide baffle rolloff?
What is the highest or most ideal point(s) recommended to cross over the sealed woofer to the OB without causing unwanted changes in sound due to the different baffle/box types/position of drivers.
Also, using Edge for modelling, what are the point sources and speaker density?
