0 Members and 1 Guest are viewing this topic. Read 6006 times.
Incredible expensive. I buy a alu round bar and took to a CNC shop to cut, result=80mm cones at $ 30 each.
A photo would help. Cones alone would not be likely to have the same effect.Have you compared the results of your DIY project with any of the Stillpoints?
Tell me again how something made out of stainless steel or aluminum isolates?Do they have springs?Is it vertical and/or lateral vibrations?
I am having vibration issues with my power supply, ten-tec 937, so I was interested but the price in the Cheap and Cheerful is slightly out of range??, what is a snake oil?
No experience but I'm interested for my turntable. Maybe someone will chime in with experience with them.I do find their ad funny, however. It reads, "Are you convinced that it's necessary to spend ridiculous amounts like $125, $250 and $700 for world class vibration control footers...?Hold on, not so fast!"And their products range from $90 to $235 each, which is $270 to $705 assuming at least 3 footers for a component (more than double the "ridiculous" sum of $125).
Exactly, I find the Isoped product so far out of the spirit of Cheap & Cheerful, as well as pricing guidelines for tweaks, that its a slam dunk that the thread needs to be moved. However, in the interest of cheerful fairness, feel free to convince me otherwise.
'technical explanation' What other kind of explanation would there be? It's a mechnical engineering thing.Just which of those many reviews?Sorry, I couldn't find a patent reference on the Stillpoints page?
I only posed the question here because I couldn't find a more appropriate Circle. Please suggest one. However, at 1/2 the cost of Stillpoints, they are cheaper. And, I must observe, have given me a more cost effective bump up than the alternatives in an already very fine system.
Seems like you'd like to dismiss the whole isolation issue (so would I as I'm old school and have a hard time spending serious coin on cables, isolation, etc.), but in the case it's real. While in the structural engineering field decades ago I ran into a dynamics genius that we used to design concrete pads for huge fans/motors used in power plants. Obvious examples a vibrational dynamics: diving boards, noisy upstairs neighbor, and turntables on soft wooden floors. It's a very complicated matter to understand completely as it deals with resonances of each piece.
