Help! Stupid Problem- Can't get my marble 4.0 open.
0 Members and 1 Guest are viewing this topic. Read 1581 times.
nitemagi
« on: 15 Sep 2004, 01:04 am »
So I'm having a terrible day.  Sleep deprived, worked my arse off all day, got a flat tire on the way home, but finally picked up my norh's from UPS.  Of course I get home, open up the center channel (4.0- marble), and look through the packaging.  I'm curious about the feet so I unscrew one, and the attaching screw falls INTO the casing.  So I figure- now big deal.  I unscrew the hex nuts, but the facing the hex nuts held in will not come off.  I'm not sure from where to pry and with what.  It's a tight fit, and I don't want to scratch the thing up or damage anything.  Anyone have any ideas? :(
jqp
« Reply #1 on: 16 Sep 2004, 12:11 am »
A trick we learned from Tyson:
Use a broom handle stuck through the rear port to (carefully) poke the driver out. Make sure you or someone can catch the driver.
I assume you have al;ready come up with a solution by now though...
