How do you know the resolution of a WAV or FLAC file you are downloading
0 Members and 1 Guest are viewing this topic. Read 1415 times.
R_burke
Most of the sites I've gone to simply offer you the chose of MP3, WAV or FLAC download without revealing the resolution of the file being downloaded.  Is there any way to tell what the resolution is before or after you download it?
barrows
after download many music player softwares will show the bit depth and sample rate (like iTunes, jRiver, etc)
srb
Most of the sites I've been to list the bit depth and sample rate.  What sites are you not finding this information on?
If you're downloading WAV, AIFF, FLAC or ALAC they are all lossless formats and are generally 16/44.1 or higher.  If they are higher resolution than 16/44.1, they are normally priced higher and because of this most always indicate whether 24/44.1, 24/48, 24/96, 24/176.4 or 24/192.
Knowing the bit depth and sample rate for lossy MP3 doesn't tell you the level of compression, so the bitrate is the indicator of relative quality for these files.  You can have MP3s that all show 16 bits and 44.1KHz in a player, but the bitrate column showing 128kbps, 256kbps or 320kbps would indicate the compression level and relative quality.  If the MP3 is encoded as VBR Variable Bit Rate, the number would be a bit less than those exact numbers.
dminches
I would recommend getting dbpoweramp.  It is a great utility to not only pull information from audio files but to also change formats (flac to wav, etc).
R_burke
Artist sites, reverbnation, bandcamp places like this
bladesmith
  • water quenching steel since 2001....
    • palmer knives
R_burke,
After you download them, right click on the file and the info should be there. You don't really know if what they have sent you is correct, until you check it, after it is downloaded.  Most of the time people do send you the right type, but sometimes people make mistakes.
good luck
