Inductors
0 Members and 1 Guest are viewing this topic. Read 1550 times.
a.wayne
Inductors
« on: 5 Dec 2014, 02:36 pm »
Dan,
Is the perfect lay air  core available  in custom values...? Looking for
.085mh
.075 mh @14g
Regards .
Danny Richie
Re: Inductors
« Reply #1 on: 5 Dec 2014, 03:46 pm »
I only stock them in 16 gauge. I do stock a .07 in the 16 gauge XQ. That is a tiny value and DCR will be really low. So I can't image needed a larger gauge.
From a measurement standpoint each time you increase a gauge from 16 to 14 or 14 to 12 you gain about 1/10th of a db of output below 200Hz.
a.wayne
Re: Inductors
« Reply #2 on: 5 Dec 2014, 10:37 pm »
Ok,
You have .07, but do you do custom values, say i need .085 or .090 ,  if not i have to pull up and down wind myself, which defeats the purpose of the perfect lay.  Also IYO how do they compare to Goertz ...
Danny Richie
Re: Inductors
« Reply #3 on: 6 Dec 2014, 03:13 pm »
I can de-wind a .15mH value down to whatever you want. You have to pay for a .15 but then again it is pretty small and doesn't cost much to begin with.
a.wayne
Re: Inductors
« Reply #4 on: 6 Dec 2014, 04:47 pm »
Tks ....
