For Sale Aragon 4004 Mk II Pristine Condition $800
0 Members and 1 Guest are viewing this topic. Read 1184 times.
dwolek
For sale is a legendary Aragon 4004 Mark 2 amp. The amp is rated at 200 into 8, 400 into 4 ohm and rated to drive a 2 or even 1 ohm load. If you have inefficient speakers, this is your amp. Functionally the amp is perfect, cosmetically, the only flaw is a missing machine screw holding the cover, other than that no scratches or nicks whatsoever. Original packaging is still in great condition so shipping is not an issue. 70lbs from 14303. See the following link for a primer on these classic amps. Note that this amp has the "superior" Mondail/Aragon labelled Toshiba round transistors. A visual inspection of the inside of the amp shows no bulging caps or otherwise suspect parts - everything looks in pristine condition. No trades. Shipping is not a problem. Asking $800.  These typically sell for 800-1000 . There is one for sale on Agon right now for $995. Check my feedback on Canuck Audiomart (dwolek) and buy with confidence.
« Last Edit: 4 Dec 2014, 09:47 pm by dwolek »
