0 Members and 1 Guest are viewing this topic. Read 6643 times.
So I've heard a few people imply that in all respects save the lowest bass, the '30 is actually superior to the 40s. Can anyone who's actually heard both in similar setups comment on this? Certainly the geometry & size of the '30 is very appealling, and is visually much less overbearing.
Hmmm...I also use 60 hz now, with 6.5" two ways. I'd assumed with a pair of 6.5 inchers, the RM30C could be x'd over that low. Is this not the case? I guess the price diff isn't drastic, I'd just though to save $ on a capability I'd never use.
I have heard the RM40s in a number of systems. I have heard the RM30s at CES 2004 and in my own system. IMHO, as stand-alone speakers, the RM40 can play louder and deeper. The RM30s have more finesse, more detail. With a Larger subwoofer the RM30s in a small to medium size room, are significantly better in virtually all aspects than the RM40. In a large room or at rock concert sound levels, the RM40 is the better speaker. Size does matter in certain things. YMMVPlus, in a small or medium size roo ...
Hello Doug,The RM30C is a very different animal than the LRC or the 626R. You will NOT be able to cross it at 40 Hz and 50 Hz may be an issue. Per Brian's latest configuration and testing (at least that I know of), the low frquency response of the RM30C is 55 Hz without the new megawoofers and 48 Hz with them. The RM30C is primarily aimed at those wanting a super high quality center channel for movies. For use with a Trinaural or for full-range music, the standard RM30Ms are probably more appropriate unless you have a very fast, extremely high quality sub that you would want to cross over at 80 Hz or so.
The RM40's have everything the RM30's have with a wider sweet spot and deeper bass. But they're also twice the size and thousands of dollars more. My RM30's have the auricaps and megawoofers. The only RM40s I heard (George's) had all the upgrades including the TRT caps. They also had room treatments and significantly better electronics.Joe M.
