0 Members and 1 Guest are viewing this topic. Read 6973 times.
I've got a 59 inch Samsung and a 50 inch Panasonic which will only be replaced if I become so obsessive about energy consumption that I have nowhere else to cut. And I may join the other dinosaurs before that.
ISometimes I find myself just gasping at the picture quality - and that happens with both of them.
Does anyone know if LG and Samsung will continue to make Plasmas? Also, does anyone have opinions on LG and Samsung plasmas in general? Do they compare to the Panasonic models?
We are close to pulling the trigger on a basement finishing project, so naturally I am starting to prepare for another flat panel purchase. In the past, I have been a strong proponent of Plasma over LCD/LED and have purchased several Panasonic Plasmas over the years. While it is clear that the LED technology is advancing rapidly while Plasma is stagnating/evaporating, I am thinking that for my needs (watching sports and movies on a limited basis in a basement), spending as little as possible on a LG or Samsung plasma is probably the best option (I can get a 61" 1080P Samsung delivered to my door for $700). I am debating between "buy the Plasma now while you can still get them" vs. the "hold off, TVs get better and cheaper with time", and I am kicking myself for not getting a Panny when they announced they were nixing production.Does anyone know if LG and Samsung will continue to make Plasmas? Also, does anyone have opinions on LG and Samsung plasmas in general? Do they compare to the Panasonic models?
Once you go projection, pfffffft, you just laugh at 65 inches...
From what I've read this is the last year for the majority of the major company's will be producing plasma's. Personally if you can budget it, I'd go with a Samsung F8500 series plasma. They're touted as being the best plasma currently made, even better than Panasonic who has consistently lead in that market. Currently Bestbuy has some deals on them.PN51F8500 - $999PN60F8500 - $1499PN64F8500 - $2,499.98While it does excel in picture quality from what I understand they're not the best gaming diaplays. They have some sort of delay built in, I believe with some of the features turned off it sits somewhere around 50ms which is still pretty bad.
