0 Members and 1 Guest are viewing this topic. Read 6560 times.
This is the spec for the most common bulk power wire:Southwire SIMpull THHN or THWN-2 or MTW copper conductors are soft annealed copper. #14 - 4/0 AWG uses acombination unilay strand and 250 kcmil and larger uses a compressed copper strand. The wire is insulated with a tough heatand moisture resistant poly vinyl chloride (PVC), over which a SIM (SLIKQWIK® Infused Membrane) nylon (polyamide) or ULThe wire itself has a PVC insulation so way or how could the box matter?
Many knowledgeable people don't say anything of the sort.I do like the topic at audioasylum 'Genuine insanity'After the AC power goes through 50 to 100 feet of metal conduits & boxes, one more won't make any difference.I'll let you do the blind test, after all it's your claim.And I'll stick with good engineering practices, thank you.
An interesting paper on AC power wiring. While Bill Whitlock has been hinting at this for decades, this paper enplanes it in detail. Just skip over the math parts and don't even try to read the patent application.Ground Loops: The Rest of the StoryBill Whitlock, AES Fellow and Jamie Fox, P.E. This paper was presented at the AES 129th Convention, 4-7 November 2010, San Francisco, CA, USAABSTRACTThe mechanisms that enable so-called ground loops to cause well-known hum, buzz, and other audio systemnoise problems are well known. But what causes power-line related currents to flow in signal cables in the firstplace? This paper explains how magnetic induction in ordinary premises AC wiring creates the small voltagedifferences normally found among system ground connections, even if “isolated” or “technical” grounding isused. The theoretical basis is explored, experimental data shown, and an actual case history related. Littlehas been written about this “elephant in the room” topic in engineering literature and apparently none in thecontext of audio or video systems. It is shown that simply twisting L-N pairs in the premises wiring canprofoundly reduce system noise problems.http://xa.yimg.com/kq/groups/20963848/268252969/name/Whitlock-Fox+-+Ground+Loops+.pdf
A Middle Atlantic white paper. Remember to read the Addendum."Power Distribution and Grounding of Audio, Video and Telecommunications Equipment White Paper""Addendum to Power Distribution White Paper"http://www.middleatlantic.com/resources/white-papers.aspx
Why would you use an Isolated Ground with a Romex®NM cable?
