Mystery box accross mains
0 Members and 1 Guest are viewing this topic. Read 1771 times.
pelliott321
« on: 23 Nov 2014, 05:07 pm »
I recently purchased a couple of used tube amps and this box was connected across the mains in each unit.
I am pretty sure its some sort of filter and has some crystals to probably soak up some stray energy.
If anybody knows what this is and where it came from I would like to know.
And any opinions on its validity
thanks
 So it goes.........
Big Red Machine
Re: Mystery box accross mains
« Reply #1 on: 23 Nov 2014, 05:14 pm »
Try looking at Kemp Elektronics, Audio Magic, and Jaguar Audio for some leads.  The new Kemp units have crystals inside but I do not see a knob on it so am not sure it is a Kemp product.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 23 Nov 2014, 05:20 pm »
That looks like an Audio Magic Pulse Gen.
*Scotty*
« Reply #3 on: 25 Nov 2014, 05:04 am »
The crystals might do something, but I pretty sure that the circuitry actually produces RF noise a la the TICE clock. IF you power it up you may be able to pick up the noise it radiates on an AM radio.
Scotty
pelliott321
« Reply #4 on: 25 Nov 2014, 08:43 pm »
Its been confirmed that it is a Audio Magic Pulse Gen.  Sells for $400
I will have to put it back in and give a listen to see if its smoke or true
