0 Members and 1 Guest are viewing this topic. Read 12872 times.
I found out that shipping my SFL-2 with the power supply (2 boxes) was going to cost me $800.00 just for shipping alone from Ohio to Canada and back, That's why I never had the SE+ upgrade done. By the time I paid for shipping and the mod it would have been around 2k.
Finally got it open and as per usual before putting on a shelf and powering up...I always open for pics and cleaning and I must say that considing this was a 9/10 I believe not..It was called recently updated by PC for $600..I think not..its got dust baked on the caps and tube rings melted..PS is scratched up and umbilical cord is coming apart...I donnot even want to power up. Im new to tubes but......
He got it from original owner 6wks ago as I just missed it..we met during a snow storm at his work so I was not able to hear or see it but he had good feedback. .I am very disappointed in this 9/10 transaction
I own a Sonic Frontiers SFL-2 preamp. There are very FEW caps that will fit in the same space as the original multicaps due to there size. V-cap OIMP's are some that DO fit and are probably the best bet. In the case of the SFL-2, some of the caps are bi-passed under the circuit board with smaller caps.Chris may have done this with yours. I was told the SE+ mod for the SFL-2 was around $850.00 but I never had it done due to the high shipping cost to Canada and back.Maybe Chris used V-cap Oimp's by-passed under the board with V-cap TFTF, that would be a great combo.Find out which tubes are the gain positions, those are the most critical spots. Put your best sounding tubes in those spots and cheaper tubes in all the other spots.Chris recommended Amperex to me for the gain tubes but I already had Siemens 6922’s.The SFL-2 runs really hot, both power supply and preamp. I like to leave the hoods off of mine. It will be hard to beat those V-caps. Put your money on the gain tubes and enjoy your preamp for years to come. Chris makes solid equipment.If you don't know which locations are for the gain tubes just email Chris Johnson at Parts Connexion, he'll tell you.
