FS: A 2014 SMSL 1955+ 24/192 DAC
0 Members and 1 Guest are viewing this topic. Read 1309 times.
trianglezerius
« on: 20 Nov 2014, 09:42 pm »
I am selling this DAC with less than 20 hours because I don't use it. I'm asking $60 plus shipping.
From the Ebay ad:
Sanskrit is a desktop mini multifunction DAC,it can connect computer to decode USB/Coaxial/Optical signals so as to improve the sound quality.Sanskrit is revised by SMSL SD-1955+ Mini DAC.
The framme of Sanskrit is SA9027+WM8805+PCM1796+OP275+JRC5532DD,perfect matching chip IC group.For Operational amplifier part,it adopts AD company OP275G&JRC5532DD comparing with Nextorn DIP8 IC socket.All the components for Sanskrit adopts high level famous components, such as US DALE(VISHAY)fever resistors,NICHICON capacitors,BB,PHILIPS capacitors,Germay ERO metal film capacitors,AD,JRC,WOLFSON,gold-plated RCA terminals,etc. ELNA top-level audio components.....
Features:
Upgrade version of SMSL SD-1955+ USB DAC
-SA9027+WM8805+PCM1796+OP275G+JRC5532DD framme
-Input :Coaxial input x1 Optical input x1 USB x1
-Output : R/L RCA output x1
S.M.S.L Sanskrit is the 2014 upgrade version DAC for SMSL SD-1955+ DAC.
Technical Specification:
Input interface: Standard Coaxial/Optical/USB cycling selectable input
Input frequency:Coaxial/Optical support 192KHz/16/20/24BIT USB support 24bit/96KHzsampling rate,it also supports 88.2KHz sampling rate.
Output interface:L/R RCA output x1
SNR: >108dB
Dynamic Range: 102dB
THD: <1KHz%0.001
Rated Output: 1.5VPP
Response frequency: 20-20KHz(-0.3dB)
Machine power consumption: <8W
Dimension: 146*98*35mm
Weight: 0.85kg
Color: Black(default)(Silver optional,Please note when you buy it.)
Print : laser carve
Case : Aluminium
Power supply : AC100V-240V input (US/EU/AU/UK plug optional)
