looking for an outboard motor pod...
0 Members and 1 Guest are viewing this topic. Read 3415 times.
Sonny
« on: 20 Nov 2014, 08:27 pm »
Hi there, I am looking for a good outboard motor, like the VPI stainless steel motor pod of old, a teres or something belt driven for my custom plinth.  I like the VPI rim drive but it makes the overall dimensions of the table a tad too wide.  Here's a pic of the table.
See how it sticks out?
Suggestions are welcome.
Wayner
Re: looking for an outboard motor pod...
« Reply #1 on: 20 Nov 2014, 08:40 pm »
Wow, you really do have a problem....................... :D
Sonny
« Reply #2 on: 20 Nov 2014, 08:42 pm »
Yes, the journey NEVER ends!
Wayner
« Reply #3 on: 20 Nov 2014, 09:04 pm »
Seriously, it does look like you are running out of room with whatever your table is sitting on. How about a new maple base for that bad boy. Lots of people like the rim drive......
Wayner
« Reply #4 on: 20 Nov 2014, 09:09 pm »
One more thing, can't the motor fit behind the table?.............and I'd still get a new maple base.
BobRex
« Reply #5 on: 20 Nov 2014, 09:25 pm »
TTWeights sells their motor and controller separately now.  That gives you the option of rim or belt drive.
Sonny
« Reply #6 on: 20 Nov 2014, 10:14 pm »
Thanks Bob, I did check the TTW stuff, too pricey, unfortunately, $2200 for the motor and controller.
I am looking for simplicity...back to belt or tape drive.
Sonny
« Reply #7 on: 20 Nov 2014, 10:15 pm »
Wayner, yes, I could put it behind the plinth, but it would be right were the backarm would drop the cartridge down, don't know if having that right there would introduce any unwanted resonance, etc.
Maple?  Yes, well, That may be an option for sure.  How much would something like 25"x20"x2" be?
neobop
  • BIRD LIVES
« Reply #8 on: 21 Nov 2014, 02:02 am »
Hi Sonny,
Have you considered the Origin Live DC motor kit?   This got great reviews and is used as an upgrade for Linn, Rega, etc.  A motor and controller start at $500.  They also have an upgraded motor and controller.  I think you max out at $1300.  Even have custom made pods:
http://audiorevelation.com/products/origin-live-dc-turntable-motor-power-supply-upgrade/
The rim drive alternative is Teres Verus motor and controller.  Some people consider this better than VPI rim drive:
http://www.teresaudio.com/verus-motor.html
neo
galyons
« Reply #9 on: 21 Nov 2014, 02:54 am »
Got my original.  You are more than welcome to try it and see if it is what you want.  Sitting in a box with the old Jr. towers. 600RPM motor, SDS pulley. We can swap out for your 300RPM motor.
Geary
Sonny
« Reply #10 on: 21 Nov 2014, 03:05 am »
Greary...yes...gives me a reason to come over.   when are you around?
Wayner
« Reply #11 on: 21 Nov 2014, 01:02 pm »
They've got 24", not 25"...........http://shop.mapleshadestore.com/products.asp?dept=189
Not a big fan of Mapleshades, may be able to source it somewhere else...
Wire Nut
« Reply #12 on: 21 Nov 2014, 01:15 pm »
Expressimo Audio just came out with an arm pod.
Sonny
« Reply #13 on: 21 Nov 2014, 06:05 pm »
Looks nice, but how much is something like that?
Wire Nut
« Reply #14 on: 22 Nov 2014, 01:55 pm »
Ooops, they make a motor pod as well  :duh:
deauguie
« Reply #15 on: 28 Nov 2014, 04:14 am »
Sonny,
Try Timbernation.com for the maple platform. He will quote you for a custom size if he already doesn't have your size available. I have purchased some of his platforms, and have been very pleased with them.
Dan
P.S.  Do you still have that mono Ace cart available?
Grbluen
« Reply #16 on: 28 Nov 2014, 11:31 pm »
Sonny,
Did I miss the thread on your custom plinth?
Grbluen
« Reply #17 on: 28 Nov 2014, 11:38 pm »
Found it!
