0 Members and 1 Guest are viewing this topic. Read 6289 times.
Subwoofer placement is more art than science I sometimes think. But gear like the Anti-Mode make it idiot-proof for decrepit old geezers like me.
Bass frequencies travel in waves, so in-room bass from a single source will never provide flat response beyond a single location at a single frequency, just basic physics. EQ can't solve that. Treatments can't solve that. Just accept it. Using two subs at the opposite end of the room is only a start. Again look up "swarm" and Duke LeJuene here on Audio Circle. Best, only "real", alternative:http://www.spatialcomputer.com/page9/page10/page10.htmlThis is a miked "reactive" sub that is located at the back wall that does not connect to your system. It produces real-time out of phase sound wave.
There are a couple of points that can be EQ'd that will tend to be consistent throughout the room. Usually it's the one related to floor/ceiling height. That's why I like Dirac so much - multiple measurement locations, so they can focus on the room modes that are consistent from place to place and softer on stuff that's specific to the listening position:http://www.minidsp.com/products/dirac-series
While I do this (because of "movie night" with friends), it is sub-optimal. FR becomes ... averaged. It roughens up a bit the really smooth FR capable when measurement is confined to a single point. So for a solitary listener in his/her favorite 2-channel room, single point eq is ideal. For multiple listeners, multiple point FR averaging is best. (Or also best if one wanders around the room a lot while listening.)
The other option is to use OB subs that just don't interact with the room in the same manner as a sealed box sub. Downside is that they don't pressurize the room the way a sealed sub does, so you never get that "I am under water" feeling. On the upside, bass clarity and detail is unmatched in my experience (not even by a swarm setup).
And what does the quality of the swarm subs have to be since they are mostly being used to even out the bass in the room?
I'm wondering if you are using speakers that are already OB like the Super V or 7, do you use more OB subs for the swarm or do you use sealed subs. And what does the quality of the swarm subs have to be since they are mostly being used to even out the bass in the room?
