Amb match for my HT2-TL's Yes or No?
0 Members and 1 Guest are viewing this topic. Read 1340 times.
Peterkjl
« on: 18 Nov 2014, 04:01 pm »
Hi, I've Got my eyes on an integrated amb called Cayin 353B which is 3 years old and out of production.
Very popular some years ago in Scandinavia.
SPECS:
Out effect: 2 x 160 Watt / 8 Ohm.
Powersupply: 800 Va
Kapacitet: 120 000 uF.
Frequency: 5 til 60 000 Hz.+/- 0,5 dB.+ / - 0,5 dB.
Distorsion: 0,07%.
Noise dampening: 93 dB.
In sensitivity: 340 mm.
In: Linje 5 / 1 tape / 1 hoved-in.
Out: 1 pre-out / 1 Sub-out.
It has to match my ht2-tl's.
I'm excited to hear your views on this one.
DMurphy
    • SalkSound
Re: Amb match for my HT2-TL's Yes or No?
« Reply #1 on: 18 Nov 2014, 05:53 pm »
SPECS:
Powersupply: 800 Va
Distorsion: 0,07%.
The only thing you would have to check is whether it's designed for 4 ohm loads.  I'm pretty sure it is, but that's the only issue I can see.
