Does the USB port you connect to matter?
0 Members and 1 Guest are viewing this topic. Read 4146 times.
BobM
« on: 17 Nov 2014, 11:43 pm »
At the Audioquest presentation at the NYC show a month or so ago I thought I heard them say that using the "proper" USB port to connect your DAC can make a difference in the playback performance?
Does it really matter which USB port on the computer is used? If so, then which one is best and how do I identify it?
randytsuch
Re: Does the USB port you connect to matter?
« Reply #1 on: 18 Nov 2014, 12:05 am »
The one that sounds best  :green:
Sorry about that.
Seriously, I bought a Silverstone PCIE to USB card, and even stock I think it sounded better than the USB ports from my motherboard.
I modded the card, and it sounds even better now.
Paul Pang and Sonore both make PCIE to USB cards that are supposed to sound good.  Given my experience I don't doubt they sound better than a motherboard USB port.
Randy
Charles Xavier
« Reply #2 on: 18 Nov 2014, 12:12 am »
Bob
 Google the well-tempered computer
ttan98
« Reply #3 on: 18 Nov 2014, 02:25 am »
Some audiophile believe that the weak link is the USB port hence a lot of development work has gone into developing an adapter to interface USB port with either a SPDIF(*) or I2S output interface. This adapter has very low jitter clock hence better audio output. This kind of adapter is not expensive, you can either buy it from Ebay or specialist shops. There are 2 types of adapters:
1. Based on XMOS chipset USB interface and SPDIF/I2S output about $50-110 of Ebay depending the quality of crystal used.
2. Based on CM6631A chipset also with same interfaces as above about $60-80.
I owned both of these adapters the XMOS is the current fad and marginally better than CM6631A
* output goes to an external DAC you may already owned and liked. Some current DACs have this XMOS built-in, if you are looking for new DAC look for one with XMOS chipset.
BobM
« Reply #4 on: 18 Nov 2014, 01:58 pm »
Bob
Thanks, I think I found my answer there. For others who may be interested (these are Win 7 instructions) ...
- plug your USB DAC into a USB port
- open Device Manager
- view Devices by Connection
- expand all USB controllers
- find your DAC and if it is on a USB port that is not shared with anything else (like Bluetooth, or your mouse controller or printer) then you are OK, otherwise move it to a different port and try again
randytsuch
« Reply #5 on: 18 Nov 2014, 03:50 pm »
There is also the Amanero which had been available at a group buy at diyaudio but I think the groupbuy price ended.
I never compared the Amanero to the Xmos, but it is considered better by some, I've read the the xmos has some compromises  in it's design.
firedog
« Reply #6 on: 18 Nov 2014, 05:03 pm »
In regards to original question: It can. Some people find that different USB ports sound different. The apparent reason is that some ports get more electrical/noise interference.
Don_S
« Reply #7 on: 18 Nov 2014, 05:13 pm »
Bob,  Thanks for the info.  I use Win 7.
ttan98
« Reply #8 on: 19 Nov 2014, 05:04 am »
Looks like the Amanero is the latest Adapter I haven't tried, hopefully in the near future. Have you?
*Scotty*
« Reply #9 on: 19 Nov 2014, 07:17 am »
Here is the Amanero board.
http://amanero.com/
Scotty
randytsuch
« Reply #10 on: 19 Nov 2014, 02:30 pm »
Yes, it is the ONLY adapter I've tried so far.
I have version 1 of this dac, and he compared a few of these, including the xmos and amanero
http://www.audiodesignguide.com/DAC32/
Although this one is more expensive, I was looking at it before, looks to have nice features
http://www.audiocircle.com/index.php?topic=127689.0
